Comments
Btw, my measured blade wobble is only .005". Not too bad.
Everyone needs one of these! Zero guess work setting up the blade or guide! Even if you are in the camp of "it doesn't need to be that tight" it sure is easy and will be simple to certify in the future!
I'm thinking of buying one of these instruments. Before hand I'm worried if motor and the shaft-Pluse-Blade would be off then what I can do ? You see my table saw was worth 300$ by the Chinese ?
