Project Information
These are two walnut lamps. The bases are 7" x 9" x 1-3/4", and the posts are about 5' tall. The LED strips, LIFX are used for the brightness, are in aluminum channels, which are glued into V-shaped grooves cut in the walnut with a router. The power cables are hidden inside the walnut.
The post and the base are joined with mortise and tenon, through which a channel cut to run the power cable.
Finish is two coats of 2 lb cut shellac followed by four coats of GF Arm-R-Seal, with light sanding between coats. This finish works really well for walnut. I was lucky to have found a bit of denatured alcohol mix for dissolving the shellac, just enough for the project-this stuff is really to hard to come by these days.
Gallery
Comments
For the first time, all the woodworking for this project was done in front of the garage in the driveway, with the garage door shut. I put all the power tools on mobile bases and rolled them out a few yards as necessary. This was done to keep all the dust outside and garage clean. Seems to be working so far.
I've seen TVs with those lights build into the back, supposed to change with the displayed scene and do some brain tricks to make everything seem much bigger/better.
Looks like a nice design and you can really tune your mood lighting!
Very cool lamps.
I like working outside on a deck in the backyard. We are having a 100° heatwave at the moment though.
Well done, keep it up!
Yes, there is a LIFX strip kit that goes to the back perimeter of TV. I might try this as well. Supposedly, it creates a transition from bright screens to dark walls to make it easier on eyes. Also doubles as an indirect light.
100° makes all finishes cure faster. Wish we had it here for a week or so. My tung oil hasn't been curing well. Might be the wood species though.
