Project Information
This is a custom wall system. It is built similar to an entertainment center, but this one will be used for just storage. A few thing to note that I did on this project. The first is the pocket doors and adjustable shelves combination. Normally the recess movement pocket doors interfere with having any adjustable shelves. This was overcome by adding a false side over the doors when pushed into the cabinet. This does two things; it allows the shelves to be used, and it hides the door when recessed into the cabinet. One note when building the false sides must be made removable for the ease of finishing and hardware installation.
I also used a lot of beadboard on this project. The doors were 5 piece doors with beadboard centers, I used ¼" bead board on the backs, and for the sides I cut small grooves 3" apart.
Another feature on this project was the distressed finish. I made some worm hole by banding together different size nails. I Drove them into the wood concentrating on one area about 2" in diameter, then kind of feather them away from the center (make lighter or less frequent) along the grain. Almost making an oval pattern I also used a chisel to make gouges in the wood on the flat surfaces and on some edges. Another distressing technique used was to take a very course file pull down the edge. I'll do one pass to file down the edges to break the edge and a second pass with the file backward at a lower angle. This puts a roll of line parallel to each other at about a 45 degree angle. And the last step is to sand the distress spots and all edges. Remember it is made to look old and warn.
The finish was a dye coat (very thin) followed by Dark Walnut stain by Minwax. On places where people would normally touch and also on the worm holes, I'd try to wipe the stain off a little more than other places. This gave it an even a more warn look. It was then followed by two coats of pre-cat Lacquer.
I don't do distressing very much, but it seams like I pick up something new each time. I used to hate distressing, but now I look forward to it.
Gallery
Comments
Nice job. I really like that hidden door trick.
It looks great. Thanks for sharing.
Great looking cabinet. Did it hurt when you did the distressing? I would have hurt me!
osconer-only when I hit my finger with the hammer. Just kidding. Really it use to hurm me but now I see it as just part of the finish.
It probably makes some of the other finishing go easier, because if you get a chipout. It's ok. No Problem.
I like it.
If we bump it or drop something during final assembly, we say "oops I just added $50".
LOL - this is funny. Great way to take your frustrations out and get paid for it.
Looks very nice Chris.
Really nice piece. I've lived through the trials and tribulations of a couple of these. I feel your pain.
It looks great! Nothing like an eight hour shift distressing shift at work.
Chris the wall unit looks fantastic nothing better than getting paid to take out a little frustration.
