Project Information
I have a Craftsman TS (model 315.228390) with an original fence that is extremely difficult to adjust. I wanted to upgrade it to a better fence. Incra LS32 was what I had in mind originally but after some more consideration I have to give up that idea simply I don't have that much room on the right side of my TS and I wasn't sure the ultra-accuracy was that critical to me.
After reading many positive reviews on the Delta T2 30" (a Biesemeyer clone), I decided that was the right fence for me and the price is definitely a plus. I ordered it from Tool Plus for $155 including shipping. It arrived in good condition in 3 days. I did not realize how heavy the carton was with just 2 steel rails and a fence!
Following many of the good advice given in LJ from various forums, I was able to install the fence successfully. I chose to drill the new holes in the rails as it was much easier than to drill into the TS wings. I got the holes drilled as close to the edge as I could but I still get about 1/8" between the fence and the top of my TS. Fortunately, the aluminum sides of the fence is adjustable (by almost 1/8") but turning the fence upside down and loosening the nuts inside. I was able to get the gap down to 1/16".
The fence glides effortlessly on the rails and I had it zeroed in on the scale right at the blade. Once locked, the fence is rock solid. I also like the adjustability of this fence. My old Craftsman fence only allowed me to rip up to 23", not enough to split a 48" board in half. My new fence now allows me to rip up to 30 3/4"! I have yet to run some test cuts but I am looking forward to putting my upgraded tablesaw to some exciting projects after the holiday.
Thanks for looking!
PS. Thanks to MikeBerry I have added a T-Track on top of the fence following his idea with minor modifications. Here are a few pictures of my fence modification.
http://i667.photobucket.com/albums/vv38/SimonSKL/008-3.jpg
Here is the front of the fence.
http://i667.photobucket.com/albums/vv38/SimonSKL/006-5.jpg
Here is the back of the fence.
http://i667.photobucket.com/albums/vv38/SimonSKL/007-3.jpg
Gallery
Comments
· Registered
I to upgraded to a better fence. I'm sure your going to love it.
Keep making sawdust.
· Registered
nice fence but im actually more interested in your above blade dust collection. that appears home made, can you give some more info on how it works?
· Registered
Mike,
The dust collection above the blade is nothing fancy, just a homemade hood made of 1/4" plywood coupled to a 4" metal connector then connected to a 4" hose suspended from my garage door rail. You can see the hose is attached to a tee coupler which also connects to my bandsaw. By adjusting the bungee cord length, I can raise of lower the hood to various heights from the top of the tablesaw. See link to the picure.
http://i667.photobucket.com/albums/vv38/SimonSKL/00312.jpg
· Registered
Very timely post. I just received my Delta T2 fence and have been debating if I should drill into the table or the rails. You have sold me on the rails. I have the same Craftsman saw and my fence was at least a 1/4" out of square. I would have to bend it over and tighten it down to get it straight. Not good for accurate cuts!! Can't wait to get it installed.
· Registered
Sean,
Since you have the same Craftsman saw, you will find out, if you attach the Delta front rail to two of the existing TS holes, the T2 fence will ride about 1/4" above the top of the TS. So your new holes will have to be 1/8" higher than the holes already drilled in the T2 fence. This way you new fence will ride about 1/8" above the top. You only need 4 new holes. I didn't count the number of the hex bolts that came with the T2 so I drilled six holes. Effort wasted. BTW, the new holes that I drilled were 3/8", smaller than the holes already drilled in the T2 fence.
· Registered
Simon,
I have an older Craftsman TS, much like yours, but without the wings. I'm considering this TS fence, but would it work on a saw without the wings? Or would it work if I built a dedicated TS station?
Thanks much!
· Registered
Looks great. I had a old craftsman table saw and i did the same thing and it was a huge improvement. I bought a Delta unisaw from a friend and he had the T2 fence attached to it. I had no room for two saws so, last saturday i stript my craftsman table down, took the motor and the T2 brackets off and took it to the dump. I now have two T2 fences.
· Registered
I bought a Delta rip fence just like yours about a year ago. I also have an old Craftsman 10" contractor's saw which I bought many years ago. It had the same junk fence and the same problems you were having. I had to clamp it to the table every time I ripped something…what a pain!! Then I installed the new Delta and my whole world changed!! It holds parallel to within 3 to 4 thousandths. I can't imagine ever needing more accuracy than that. (I wonder why I didn't buy it sooner). I know you'll love the results you get. Great choice!!
· Registered
Thank you. Your report convinced to buy. I just placed my order.
· Registered
I have had this picture on my favorites for a long time,I wanted to ask you what you made throat plate out of,since it looks like you have the same saw I do.Just got the time to install a Delta fence on my saw and a throat plate to replace the metal one on saw is next.PS I used your idea and put peg board an lower part of saw to store push stick on small jigs and commonly used small tools,good idea.Thanks.
· Registered
I am thinking about installing one of these systems on my craftsman table saw I have 2 of them I am going to hook edge to edge and put 2 extensions on the outside of each one this would give me a width of 88". Does it look very hard to make a longer rail system like 8 feet long? I want to be able to leave a dado head on one and saw blade on the other for easier change overs and get the benifit of the larger table surfice also. Looking at pictures it just looks like alot of hole drilling and I am a millwright by trade woodworker by pleasure. and coments would be great.
· Registered
I am interested in the router table built into the wing of your table saw. I would like to know where you it and how do you like it.
Thanks for your help,
Sonny
· Registered
Well done.
