Journal Content
Series Name
Feeling Groovy a Box Project
Need a lot of grooves made. To house both the lid's panel and the bottom of the box...PLUS a groove for the dust seal...Best tool I have for that?
Is a Stanley No. 45. Set up with a 1/4" wide straight cutter...Then figure a way to hold the parts still, long enough to plough the grooves needed..
Yes, it IS screwed down to the bench....this is afterall a WORK bench, NOT some Dinning Room table top..1/4" x 1/4" groove, set 1/4" up from an edge. turn the part around..
and do the other edge....including the longer sides...
So far..that is 8 grooves done... only 4 more to do..
Except..this one has to go here....and the short rods on the 45 will NOT reach that far...
We have ways..
The Stanley 45 also comes with a set of long rods...simple enough to switch out
There is to be a groove milled on the outside of this box, that barely overlaps this one...to form a dust seal.
I also spent a bit of time, to size the panels to match the grooves...then add a rebate all the way around..
Can not do a full dry fit...would never get it back apart...
Spent this morning doing a final fitting of the panels...trying to avoid them being too tight...even trim them a bit..before a glue up could happen, this morning....
Stay tuned...one more groove to mill..tomorrow..
Comments
· Premium Member
Fine tuned the fit of the panels this morning...then the cussing could begin...
Finally...we have a glue up...Intend to fill in the square holes tomorrow. When the clamps come back off, I need to mill the 4th groove to split off the lid....then I can fill in any holes. Need to clean up the glue joints, too..
Stay tuned..
· Premium Member
Well...the 4th groove went in the wrong location...
Too late, now...once the 4th groove is milled...I removed what little was left of the Dust Seal...
And a plane to level things down. Then see about some hinges...
Goodell Pratt Co. drill to do the pilot holes. That screwdriver is a Phillips...then see about a latch..
Nice to have a box of Hardware. Before I can add handles to the ends...
I have a few holes to fill...this one was a bit large..the rest not so much...then a saw to trim each flush..
What holes? Then the handle on the ends...
Then see about a finish..
Stay tuned..
· Premium Member
So....a coat of Witch's Brew ( half stain mix, the other half Amber Shellac)...
Then hit it with a branding iron...just the right amount of "roughness" to fit right in with the shop..
A view from the hinge side of things...and
The handle on this end ( there IS another down on the other end,BTW)
Since this is a Shellac finish...I think I can call this done?
The Project was to see IF I could build something with a single board....actually...there is still a wee bit left over.
All 6 parts came from a single Pine board...1/2" x 6" x 6'.....seemed about right to build a box with?
Thanks for looking in!
