Project Information
In making this plane rack (out of sapele), I borrowed most of the moulding planes seen here from a good friend who is also a wooden plane expert to figure out the size of the rack. (I don't think I will have a collection of that many wooden planes at the end of the day.)
The beading tool was Veritas Plow Plane with a beading cutter, which worked like a charm (http://www.leevalley.com/en/wood/page.aspx?p=74143&cat=1,230,41182,43698).
The joinery tool was the Festool Domino Joiner, which is a game-changer for furniture and cabinet making.
Two shop tips to share:
1) To remove the glue squeeze-out, I used a shop-made chisel plane (gleaned from the Fine Woodworking magazine: http://www.finewoodworking.com/2016/11/02/turn-a-block-plane-into-a-chisel-plane)
2) To protect the workbench top, I turned to a retractable blind:
The rack is installed on the wall next to the chisel cabinet, using the French cleat system.
Gallery
Comments
Nice cabinet and I love the Domino cutter.
Jim
Great work. If you start acquiring more wood planes I'm sure you will need to build a second one. :)
