Project Information
4-way Elm Wrapped box
  • Carpathian Elm burl veneer four-way book matched
  • On 9-ply Baltic birch
  • Miter folded (router table) then corners chamfered to reveal birch "stringing"
  • Horton Brassworks hinges
  • Custom lid stays from 1/8 brass bar and rod
  • Wenge frame base and lid lift
  • 10×6 x 5.5 H inches
Pictures:
top:
back:
left-side:
right-side:
open:
hinge and stay zoom:
corner zoom:
bottom:
lid stays:
book matched panel before folding:
Thanks for any comments and suggestions.
Full sized pictures are here: https://adobe.ly/2IbHEMH
Gallery
Comments
· Registered
I am singularly wrapped... that is exceptional.
· Banned
beautiful box,excellent veneer work that elm just pops.
· Registered
Nice work. Outstanding veneer. Thanks for sharing.
· Registered
Finished with shellac and Renaissance wax. Thanks for the comments
· Registered
Absolutely BEAUTIFUL!!!
· Registered
Oh, such beautiful use of such gorgeous veneer - you did it true justice!
· Registered
Wow, that is a great piece. Beautiful finish
· Premium Member
Fabulous job. I love the book match and great choice of the elm.
· Premium Member
Very very very very nice! It's so easy to screw the whole veneer thing up. What was the substrate under the veneer? I like the thin chamfered line of birch edging.
Is that one of these Woodcraft/Rockler veneer packs with the center on the top and the rest cut to lay on the sides? Did you veneer all 4 sheets to the bb ply then cut? I'm making a cremation container for a friend's wife who passed away and that top is stunning! What are the dimensions? I know I've got a lot of questions. Sorry, but I love the look of this. :)
· Registered
Great use of the burl and the contrast with the wenge is perfect. I would have prefered to see wenge veneer covering the ply when the box was opened, and possibly a wenge string on all the corners.
· Registered
@Andybb
- substrate under veneer? Birch plywood, the euro style 9 ply, 1/2 inch thick. I think this is too thick and heavy for a box this size, but the hinges I owned already caused me to accept it.
- veneer was purchased from Carlton McLendon Rare Woods & Veneers. I bought a flitch of 16 so you'll see it again on a future project
- the veneer four-way book match is designed, cut and taped before gluing onto the substrate, see https://www.lumberjocks.com/projects/412968 for pictures and description from a similar effort.
- after building a veneered panel, then I cut miters and folded, see my https://www.lumberjocks.com/projects/159066 as an example of the technique used.
- dimensions are listed above 10×6 x 5.5 inches
· Registered
@madburg
- I too thought that I might should cover the plywood edges, but chose not to because it would interrupt the pattern on the outsides while closed. I hope to have achieved a clean look while closed and realize I've sacrificed something when open. I'm thinking on my next one, I'll try and dye or stain the ply edges to match the wenge. Or, maybe try and construct the panel such that there is a hardwood strip where I plan to cut off the top.
- re: stringing, the exposed birch is really an adaptation when I found that the elm more cracked than folded during assembly. I considered a more traditional approach to stringing as you suggest but not ever having tried it then decided on simplicity again.
