Showcase cover image for 10 min ugly router table
Project Information
So I have been needing a router table for some time. Two problems one I have very little space and two if I went out an just spent $100 on one with a baby on the way my wife might not be to happy with me. So after watching some of Steve Ramseys videos I figured I could just build one cheap. Well the space was still a problem so I decided to see if this idea would work and for what it is I could not have asked it to work better. One side has legs and the other side I can clamp to my current work bench. When I am done just pop off the clamps and put it out the way. I still need a fence for it and would like it to look a little better but for now it will get the job done.
Gallery
Comments
Looks a lot like mine! I needed to slap something together to work as a router table. I spent a couple hours on it and it manages to do the job - even if it is ugly as can be.
After all it was a temporary set up and I planned on making a nice one later.
That was 28 years ago! I still use it.
And I still plan on making a nice one later…
My theory does it work… then it doesn't have to be pretty… My router jig
Well done
Looks schmooks. for a fence a straight piece of lumber with a couple of clamps and you are good to go.
It's no uglier than mine. I threw one together from scrap plywood and salvaged laminated shelving, like Steve posted above, it was only meant for one project then I was going to build a nice one… that was at least 5 years ago and I'm still using it.
If it works than it's good.
Your descriptive powers are amazingly accurate. That router table is immensely better than none at all (if it works).
Looks like a great solution to a problem.
CtL
My first table saw, over 40 years ago, was a portable circular saw, fastened to the underside of a piece of plywood setting on a couple of saw horses and a board with two clamps for the fence. Set up took some time but I made a lot of stuff I needed for my young family back then. I did the same thing with my first router table when I was in a jam and needed one. I use a sink cut out scrounged from a scrap pile. "Pretty is as pretty does", my MOM used to say.
We all have to start somewhere . Good for you : )
Looks great and I'm sure it works fine too.
For a fence you need nothing more than a flat edged board. If you don't have a jointer you can simply use double stick tape or nails to attach a known straight edge to the fence and rout the edge true with a flush trim bit.
If you want to make the top a bit more durable, sand and spray on a couple coats of clear finish.
And it looks great.
Much nicer than the formica on my router table, which can only be described as "vomit orgy", but hey, it was a $12 "damaged" sheet.
