Review by Redoak49 | posted 01-21-2022 02:25 AM | 1487 views | 0 times favorited | 9 comments | ![]() |
- FastCap Little Lipper
- Brand: FastCap | Category: Routers
I bought this based on the previous review. I am building some drawer units with 1/2” plywood edge with 1/2×1/2 Oak strips. When I have done this in the past, it has taken a lot of time to get the oak even with the plywood.
With the Little Lipper it was a very fast easy process. I did have to drill a hole in the bottom plate of the router but this was easy. For a router bit, I used a 3 cutter Freud bit and it left a smooth cut. I wish that I had this in the past.
9 comments so far
CharlesA
home | projects | blog
3470 posts in 3256 days
#1 posted 01-21-2022 02:02 PM
Nice confirmation. Mine arrived yesterday.
Peteybadboy
4840 posts in 3408 days
#2 posted 01-24-2022 10:01 AM
Thanks for the review.
I will order one.
-- Petey
Peteybadboy
#3 posted 01-28-2022 10:43 PM
Mine came today.
-- Petey
Buck_Thorne
149 posts in 2530 days
#4 posted 01-29-2022 05:50 PM
How does it work, and what does it add to the flush trim bit that you’re already using? Guess I’m a little confused.
Redoak49
5585 posts in 3447 days
#5 posted 01-29-2022 07:21 PM
You will be less confused if you go to the FastCap site and watch the video.
Ocelot
3808 posts in 4097 days
#6 posted 01-29-2022 08:24 PM
Long ago I did that with a belt sander. Worked ok, but I wrecked a few shelves sanding through the oak veneer. I’ve never been much of a router man. I took a look at the videos on fastcap site. Looks like this would be a great help. Much better than trying to register the router base against the edge of a 3/4 thick board.
-- I intended to be a woodworker, but turned into a tool and lumber collector.
Underdog
1908 posts in 3494 days
#7 posted 02-02-2022 03:34 PM
Thanks for this review! This is a very helpful tool.
I see how the white bearing part works, but what is the red flange for?
-- Jim, Georgia, USA
Redoak49
#8 posted 02-02-2022 09:12 PM
The original version did not have the red flange. It helps keep your hand out of the router bit.
Underdog
#9 posted 02-02-2022 09:36 PM
Ah! Thanks! Good to know.
