Not at all happy with it.
Review by ic3ss posted 09-10-2021 02:28 AM 969 views 0 times favorited 14 comments Add to Favorites Watch
Not at all happy with it. Not at all happy with it. Not at all happy with it. Click the pictures to enlarge them
I bought this to go on top of a cabinet I’m working on. I just put in my Jesse router lift an come to find out the lockdown screw holes are misaligned. The top comes with these plastic blocks for the levelers and lockdown screws that you screw into the bottom. That’s my first complaint is other companies will machine a shelf in the hole for the plate to sit on, not here. And now after I’ve drilled into this thing and can’t take it back I find out I can’t lock it down.
So thanks Kreg, and Jessem, and probably the whole router industry for not having standards that your customers can rely on. Damnit!
Oh yea, the table also sags in the middle by about 1/32” so beware of that too.
Wayne
-- "I am endeavoring, ma'am, to construct a mnemonic memory circuit using stone knives and bear skins."
View ic3ss's profile
ic3ss
402 posts in 3993 days
14 comments so far
View pottz's profile
pottz
20151 posts in 2201 days
#1 posted 09-10-2021 02:35 AM
easy wayne just calm down.dont worry about locking it down,ive got an old jointech clincher and table top.my jessem router lift plate just sits in the opening.it’s not locked down and ive had no issues.as long as it sits in the opening fairly snug,dont worry about it.as long as you can level it ok you should be good.
View LittleBlackDuck's profile
LittleBlackDuck
7924 posts in 2037 days
#2 posted 09-10-2021 08:58 AM
Unfortunately ic there are far too many combination for all manufacturers to compromise and create the same…
Patents were designed to stop others from copying your ideas and now people complain about incompatibility…
Just look at all the crappy clones after the Fein patent expired.
Often it pays to do your due diligence, pick a brand and stick with it through thick and thin… wouldn’t be nice if one battery could be used in all brands of cordless tools.
That tabletop looks like it’s designed for a sub-frame… should not be hard to whip up a base out of MDF (without adversely affecting workable height) and you can custimise it to your hearts content… it may also assist in fixing the sag… far too often people neglect the center support in their tabletop fixtures…
I am renowned for trying new things without the appropriate investigation and often faced with compatibility issues… being an impulse buyer, this will forever plague me, however, one thing I’ve learn is to NOT doctor any new item until I consulted the supplier/manufacturer so that a return option remains viable… and further negotiations are voided when I take out the scalpel.
It’s nice to point out that this branded tabletop does not have a lip, which should be obvious unless purchasing online… it’s also a fair call to say that ”item A” is not compatible with ”item B” (without modification), however, I think you are being a tad optimistic (and believer in miracles) in calling out incompatibility across a diversified range of equipment.
Hell in an ideal world all women would choose to be married to that one perfect man.
View Redoak49's profile
Redoak49
5368 posts in 3205 days
#3 posted 09-10-2021 11:17 AM
Interesting review….the next table I build will use the precision levelers. The table being out of flat is not good.
View northwoodsman's profile
northwoodsman
650 posts in 4963 days
#4 posted 09-10-2021 12:51 PM
A couple points here. It appears that the top is made from MDF. Phenolic is often a better choice in my opinion. I have never seen a router plate that “locks” in, the weight of the router and the lift is more than sufficient to hold it in place in the table. Are you sure that the method that you used to mount the table to the base didn’t cause the 1/32” sag? Can you shim it to remove that 1/32” sag?
-- NorthWoodsMan
View MattR's profile
MattR
19 posts in 2220 days
#5 posted 09-10-2021 01:14 PM
ic3ss - Jessem sells levelling pads which should be compatible with your plate. The description states they are compatible with the Kreg tops.
https://jessem.ca/collections/router-table-accessories/products/corner-levelling-pads
Matt from Kingston
View Mike_D_S's profile
Mike_D_S
778 posts in 3431 days
#6 posted 09-10-2021 01:22 PM
INMHO the sag is way more of an issue than the lift not screwing down. As mentioned above by some of the others, my lift is a snug fit in the table and with the router attached doesn’t move around at all.
-- No honey, that's not new, I've had that forever......
View brtech's profile
brtech
1163 posts in 4139 days
#7 posted 09-10-2021 06:44 PM
The Kreg lift has a weird leveling system that needs a different cut out than most. I assume the table is cut for the Kreg lift. I have the opposite problem with a Kreg lift in a Woodpecker top. There is a quick fix that’s good enough for that, but you may need more work to make them play well together.
Yeah, I really do wish there was a single standard. It really isn’t serving our needs to have this much variation. The Kreg leveling system is clever, but is not clever enough to make up for a non-standard pattern.
pottz
#8 posted 09-10-2021 07:03 PM
INMHO the sag is way more of an issue than the lift not screwing down. As mentioned above by some of the others, my lift is a snug fit in the table and with the router attached doesn t move around at all.
- MikeDS
+1
View Lazyman's profile
Lazyman
7826 posts in 2604 days
#9 posted 09-11-2021 01:25 PM
- MikeDS
+1. I would return it for that problem alone.
View BobHinden's profile
BobHinden
18 posts in 864 days
#10 posted 09-11-2021 04:58 PM
Like others have said, if it isn’t working to your satisfaction, return it.
My guess is that a Jessem table and Jessem lift, or a Kreg table and Kreg lift will work better for you.
I have the Kreg router lift in a Kreg table (same as you have, I think) and it works fine.
-- Bob Hinden / San Francisco Bay Area
LittleBlackDuck
#11 posted 09-11-2021 09:39 PM
Like others have said, if it isn t working to your satisfaction, return it.
- BobHinden
I believe the “dodgy” has been doctored, making return negotiable… however, if it is dodgy, it should be replaced regardless of any alteration.
Nonetheless, why the hell am I writing this… it should be upon the absent OP to make such replies who should have liaised with the supplier/manufacturer.
View iminmyshop's profile
iminmyshop
389 posts in 3210 days
#12 posted 09-12-2021 02:05 AM
- I’ve not seen every router plate out there but the many I have seen do not lock down.
- If it’s out of flat that’s a big deal. What has customer service said?
-- http://www.alansfinewoodworking.com/
View Foghorn's profile
Foghorn
1273 posts in 603 days
#13 posted 09-16-2021 01:13 AM
- LittleBlackDuck
Ahem. I’ve found that one wife is all I need!
-- Darrel
View pintodeluxe's profile
pintodeluxe
6484 posts in 4029 days
#14 posted 09-21-2021 06:27 PM
Can you just re-mount the levelers so they align with your plate?
