Ridge Carbide Ts2000 FLAT BOTTOM SUPER BLADE
Review by stevejack posted 07-15-2020 01:30 PM 1198 views 1 time favorited 15 comments Add to Favorites Watch
Ridge Carbide Ts2000 FLAT BOTTOM SUPER BLADE No-picture-s No-picture-s Click the pictures to enlarge them
I have been wanting one of these blades for sometime. Last week I got a gig that this blade would be perfect for. So I got it yesterday and MAN how have I lived without this blade.
A surprise was it is one of the sharpest blades I have ever used. It glided through some red oak like butter even being a full kerf blade.
I made the bottom of my dados glass smooth. Before I had either used Blades that left FULL BAT EARS or even expensive Dado stack blades that make a cut that looked like the bottom had been chopped out with a Hatchet.
The teeth are huge chunks of razor sharp carbide.
The only bad thing about this blade is why didn’t I get this years ago.
Pricey at @ $150 but worth every cent.
View stevejack's profile (online now)
stevejack
109 posts in 119 days
15 comments so far
View BurlyBob's profile
BurlyBob
7689 posts in 3065 days
#1 posted 07-15-2020 01:48 PM
That is impressive. I might have to research them.
View Mike_in_STL's profile (online now)
Mike_in_STL
1249 posts in 1333 days
#2 posted 07-15-2020 05:37 PM
I’ve got the TS2000 combo blade on my Laguna Diamond Platinum saw. It’s a wonderful blade and makes beautiful cuts. When the woodworking shows hopefully come back through next year, I want to get their Dado Stack.
-- Sawdust makes me whole --Mike in STL
View pintodeluxe's profile
pintodeluxe
6171 posts in 3612 days
#3 posted 07-16-2020 05:57 PM
I ve got the TS2000 combo blade on my Laguna Diamond Platinum saw. It s a wonderful blade and makes beautiful cuts. When the woodworking shows hopefully come back through next year, I want to get their Dado Stack.
- MikeinSTL
That Ridge Carbide Dado Master looks too good to be true. I’ve been using an Infinity Dadonator, which is also very good, but leaves definite score lines on through tenons wider than 3/4”. That true flat bottom cut is very interesting.
View LittleBlackDuck's profile
LittleBlackDuck
4966 posts in 1620 days
#4 posted 07-17-2020 08:11 AM
If it’s great, it’s never too expensive… It’s just that people are too tight-arsed to buy whats good for them.
Far too many people strive to save that shekel or two, only to spend twice the saving in labour on workarounds.
stevejack
#5 posted 07-17-2020 10:05 AM
Yes you get what you pay for. This blade is magic
If it s great, it s never too expensive… It s just that people are too tight-arsed to buy whats good for them.
- LittleBlackDuck
View Andre's profile
Andre
3622 posts in 2605 days
#6 posted 07-17-2020 03:10 PM
I have the Dimar 24t FTB from Lee Valley after many years still sharp, hope yours stays sharp as I have had not much good to say about any Rigid blades used so far, appeared to lose there edge too fast?
Mike_in_STL
#7 posted 07-17-2020 05:13 PM
- Andre
Rigid or Ridge Carbide? Two Completely different companies.
View therealSteveN's profile
therealSteveN
5901 posts in 1373 days
#8 posted 07-18-2020 03:41 AM
I have been using the Infinity 8” flat top saw blade in 0.250 and it’s an awesome flat bottom cutter for 1/4” exact cuts, for drawer bottoms, and I do a lot of dado rabbet joints for making drawers and such. I find it’s a lot quicker both on set up, and execution than using a router table. Truly flat bottom cuts with it. The biggest plus is I don’t have to deal with the jerk who owns Ridge Carbide anymore.
-- Think safe, be safe
Andre
#9 posted 07-18-2020 04:56 AM
- Andre
- MikeinSTL
Never noticed that, not much blade selection around here, have never heard of Ridge Carbide?
View chem's profile
chem
41 posts in 2404 days
#10 posted 07-19-2020 02:17 AM
That cut is impressive (although it must have taken many passes to acheive). It is true that dado sets leave some grooves, but my understanding is that this is to make clean cuts in plywood. It would be interesting to see how this cuts plywood. I have actually found the grooves (which are prominent) to be really useful when cutting tenons. As I finesse the tenon width I can use the presence of the groove to gauge my planning progress.
-- chemist by day, woodworker time permitting
stevejack
#11 posted 07-19-2020 10:57 AM
NO this blade is not a DADO. It is what its advertised to be a A Full kerf 1/8 inch precision ground hard as hell steel and Carbide Flat bottom cut blade. I was so impressed I got a Think kerf blade yesterday. I made a few repeat passes that is for sure! BUT there are times you just need a couple/a few say Lap or Dado joints and don’t want to bother setting up for a dado blade, taking off your riving knife and putting in your dado insert.
I have tried every STACK DADO under say $200. Every single one SUCKS BAD. Now Ridge Carbide has a Cherry DADO setup for around $400 That people are going sterile singing its praises. I got one of those on my list. BUT hard for me to justify a BLADE that costs as much as your table saw.
Ridge Carbide also has a sharpening program for their stuff. My Blade here will cost @ $20 to sharpen And worth every penny ALTHOUGH more than one person has told me they have never had to sharpen their Ridge Carbide blades…...
I tried make shift sharpening rigs for your Home Depot and Lowes Blades. You end up giving them to your Friends that do Metal work.
- chem
LittleBlackDuck
#12 posted 07-19-2020 12:09 PM
... You end up giving them to your Friends that do Metal work…
- stevejack
Or your not-so-favorite woodworker “friends”.
View chem's profile
chem
#13 posted 07-19-2020 04:06 PM
Another aspect of the advertising from Ridge is “Not for cutting plywood veneers”. This is the main difference you will see vs. dado blades or alternating bevel blades. Those little extra ridges are there for a reason. Bottom line is it is nice to have different blades for different applications and this looks like a good type to add to my collection some day.
View bobasaurus's profile
bobasaurus
3644 posts in 3983 days
#14 posted 07-20-2020 06:24 AM
I have the thin kerf version and it is a good blade, though it does slightly bat ear my cuts despite the flat top grind.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View AlanWS's profile
AlanWS
66 posts in 4357 days
#15 posted 07-25-2020 04:14 PM
A box joint blade cuts either 1/4” or 3/8” flat-bottomed grooves without bat ears. Since they were introduced by Freud a few years back, lots of companies make them, and some have other widths.
As others have mentioned, the bat ears on dado sets are functional.
-- Alan in Wisconsin
