Angry Mama !
Review by MamaAnn posted 06-11-2020 10:50 AM 3085 views 0 times favorited 31 comments Add to Favorites Watch
Angry Mama ! No-picture-s No-picture-s Click the pictures to enlarge them
I’ve had this saw for only 20 mths, it’s always had a problem blowing breakers and now I can only get about 3 cuts before it shuts down when it gets hot. I’ve already replaced capacitors like they told me. Took 3 weeks to get those. This is costing me money! So many motors going out on Delta table saws that the motors are on back order. They want me to drive my saw an hour and a half away and just leave it. Had to practically fight them to send me a motor that they are going to void my warranty over and it hasn’t even shipped yet. I had to go up 3 levels of managers to get that and I’m still waiting on a tracking number 5 days later after I was told 3-5 days to receive.
I’m beyond angry !
View MamaAnn's profile
MamaAnn
12 posts in 513 days
31 comments so far
Craftsman on the lake
3882 posts in 4682 days
#1 posted 06-11-2020 01:29 PM
Don’t know what to say…. Rock and hard place here. I’d be angry too.
I know it’s less than an optimal solution but if it’s the motor, and you’re eventually stuck with the saw, and it still is an issue. A third party motor of the same size maybe? I hate to even mention this as you should be able to get some satisfaction from the company about this. It seems like they’re overwhelmed with issues and are treading water on this one at everyone’s expense.
I just did a search online for this saw’s model number with the word ‘issues’ after it. Lots of forums about the motor stopping mid cut. Lots of possible solutions, or at least solution recommendations.
View RCCinNC's profile
RCCinNC
514 posts in 1571 days
#2 posted 06-11-2020 11:28 PM
Sadly Delta is no longer the company it used to be. If reviews are any indication, quality issues, parts availability, and poor customer service seem to have suffered dramatically in recent years.
I have a Delta air cleaner hanging from my ceiling with a faulty control panel. A replacement part was on backorder for months, and then suddenly became unavailable. I finally added a manual switch and was able to keep two of the three speeds. I turn it on/off with a yardstick. My Delta drill press started to suffer quill run out. The aluminum housing/quill interface had become sloppy after only a few years of medium use. To repair this, I took a grinder and cut a slot down the front of the housing and through to the quill sleeve. I bored a hole horizontal to the vertical cut and used a thru bolt to tighten the sleeve, much like an old style split head drill press. Ugly, and it works pretty well now, but I should never have had to do it in the first place.
I also have Jet, Grizzly, Powermatic, General(Canada),Oliver, and Sawstop represented in my shop. Delta is the only brand I’ve ever had issues with. I will never buy Delta anything again.
So yes, you should be upset! I agree with Craftsman on the lake, Delta’s treading water, and are either having serious supply issues or simply have ceased to really care about their customer base. I also think your best bet is to probably look into a third party motor if you can’t get satisfaction from Delta. A bitter pill to swallow, but less expensive than a new saw. What I do not know is whether the motor in your saw is designed specifically for it, and not a standard NEMA frame.
Really sorry you’re dealing with this. I hate it when companies don’t stand behind their products!
-- Live to putter...putter to live!
View LittleBlackDuck's profile
LittleBlackDuck
8108 posts in 2065 days
#3 posted 06-11-2020 11:54 PM
I can sense your frustration and be doing more than civil correspondences, however, your 4 out of 5 star rating has me more frustrated.
BTW… Welcome to LJ.
Apologies… just noticed you 1 star (bravo)... I misread the 4 starts in the top righ by other reviewers. We need moire reviews to balance out the dodgy products getting good ratings.
#4 posted 06-12-2020 12:16 AM
Years ago it was either Delta or Dewalt. Both good companies. Dewalt seems to have maintained some of that good name. I don’t do Delta any longer.
I had a Delta/Rockwell contractors saw I bought back in 85. Couldn’t kill it. Still running in my nephew’s cellar today only the belt has changed.
LittleBlackDuck
#5 posted 06-12-2020 12:33 AM
.... I had a xyz contractors saw I bought back in 85. Couldn t kill it. Still running in my nephew s cellar today only the belt has changed.
- Craftsman on the lake
Similar to my contractors saw… some generic production line made in Taiwan… No longer sold as their cost escalated to match the production quality (originally under priced) and woodworkers refused to pay the increased price…
Unfortunately you get what you pay for… even sales tend to concentrate on factory seconds/rejects…. caveat emptor!
MamaAnn
#6 posted 06-12-2020 01:45 AM
I’m not sure how it got 4 stars, I meant for only one :D
BTW… Welcome to LJ.
- LittleBlackDuck
MamaAnn
#7 posted 06-12-2020 10:08 PM
The New motor came today ! Anyone want to come help me install it ?
J/K I got this.
Wish me luck that it works.
RCCinNC
#8 posted 06-12-2020 10:12 PM
Good luck MamaAnn!
Let us know how it goes!
View DS's profile
DS
3956 posts in 3665 days
#9 posted 06-12-2020 11:33 PM
You might check your electrical circuit feeding the saw.
Likely you would need a 20A circuit on 12AWG wire. (Top of my head assumption here, since I don’t know the actual specs)
A 15A line on 14AWG might be browning out the voltage (and popping 15A breakers), causing your issues.
It might be worth monitoring the line voltage (safely, of course) while the saw is running to see if this is an issue.
-- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS
View EricLew's profile
EricLew
273 posts in 2610 days
#10 posted 06-13-2020 12:09 AM
Good luck MamaAnn. I am sorry to hear you have had such trouble. I am one of the many owners of this saw here, and most of us love it. I have had mine 6 years without a single complaint. Either you got a lemon, or there may be some power issue. Either way i hope it works out for you
-- I love the smell of coffee in the morning, and sawdust in the afternoon
MamaAnn
#11 posted 06-13-2020 02:16 AM
I’ve had the electrician over to check wiring. All is good
Lots of lemons on the type one motor
I’ll get back to you when I’m done.
Just hoping the motor is good.
View pottz's profile
pottz
20680 posts in 2229 days
#12 posted 06-13-2020 03:18 AM
yeah as said this is an awesome saw for the money,maybe it’s there problem or maybe it’s a problem on your end? ive heard ove very few complaints on this saw,maybe you got a lemon? mine has been incredible for the money.
MamaAnn
#13 posted 06-13-2020 11:22 AM
There have actually been less praises on the saw then complaints and motors are on back order. All with the same problem…....T1 or T2….I have T1
How can the problem be on my end. I’ve had my wiring checked, The saw is clean, I take care of it, and I’ve been operating table saws most my life. The motor quickly over heats and dies. That’s the machine
RCCinNC
#14 posted 06-13-2020 01:51 PM
When we moved to our new house and before I built my shop, I kicked the cars out of the garage and worked in there. All my tools were 110 at the time, but I found that my Old Delta Contractors saw. (a great saw BTW!) lacked power and would bog down. My breaker box was in the garage, but the garage outlets were at the tail end of a long run GFI circuit. It was fine for a power drill or sander, but anything that required real current showed obvious bogging. I added two separate 110 20 amp outlet circuits, using 14 gauge romex and when I bought my General T650 cabinet saw, a dedicated 220 with 12 gauge romex.
Some motors are more susceptible than others to long runs. Years ago, I had a friend with a jointer planer that had a Baldour motor, a highly respected company, and he had similar problems. For shorter runs, the motor you have might be generally adequate? I have no idea if this is an issue for you, but the shortest run possible to your box is always a good idea and potential added insurance for your saw if the motor is susceptible to brown out. If your electrician did not check your wiring under a similar load, he wouldn’t necessarily have noticed this.
Or, the motor you had was junk, and hopefully the new one will be fine. If it does have similar symptoms, I’d look at my wiring, not just for adequate gauge which I’m sure the electrician checked, but for the outlet’s wire run to the box.
Hope it all works out!
MamaAnn
#15 posted 06-14-2020 02:17 AM
well 7 hours later “minus the break to take care of the grand daughter”
The saw is purring like a kitten and I’m covered in bruises. All I have left to do is put the dust collector back on.
Thinking of grabbing a new switch, this one isn’t in the best shape
good night folks
showing 1 through 15 of 31 comments
