Delta 36-725 Table Saw Unboxing and Assembly
Review by Dimensions posted 01-28-2020 02:28 AM 4176 views 0 times favorited 18 comments Add to Favorites Watch
Delta 36-725 Table Saw Unboxing and Assembly No-picture-s No-picture-s Click the pictures to enlarge them
So for a while now i have wanted to upgrade from my old job site saw to a new Table Saw with a cast iron top. Like many of you i am on a budget as i have four children to raise so i think long and hard before purchasing a new tool like this. After much research i settled on the Delta because it had all the features i was looking for and at about half the price of the nearest competitor. Ive only had the saw for about 3 months now and as of now i LOVE IT!!! Its been a tremendous upgrade and i know my cuts will be true and straight every time.
If you want to see my initial reactions and the assembly procedure for this saw you can check out the video I made here: https://youtu.be/rioIhld1hTg
-- Get better every day!
View Dimensions's profile
Dimensions
108 posts in 1756 days
18 comments so far
View pottz's profile
pottz
21411 posts in 2275 days
#1 posted 01-28-2020 07:33 PM
i wanted a second saw setup just for doing dadoes but didn’t want to spend thousands,this saw was the answer.for the money this saw has been a bargain,i love it.the riving knife guaud is very easy to remove and the fence is also very good.i feel delta products have gone down over the years but this saw is a great bargain.id give it 5 stars too.loved your video also.
Dimensions
#2 posted 01-28-2020 07:44 PM
Larry, I’ve really been happy with this Saw, and of course they don’t make anything like they used to….. if i could outfit my shop entirely with solid cast tools from the 50s I’d go that route but unfortunately like i mentioned in the video the salt water ( even in the air) kills steel and iron here so it’s rare to find as much as an old hand plane that is salvageable.
I’m sure down the road I’ll upgrade again to a 220v Saw because the only issue I’ve had with this one is running 8/4 hard maple and bogging it down, but the same could be said for nearly every 110V saw out there.
Thanks for the feedback and I’m glad you enjoyed the video! Stay tuned to the channel and see what i make with my new Saw !
View Dustin's profile
Dustin
707 posts in 2031 days
#3 posted 01-28-2020 08:51 PM
I’ve had mine for years and it’s served me very well.
Regarding your comment on the maple, what type of blade are you using? When I was still using my thin kerf combination blade for ripping, 8/4 cherry and maple slowed me down a ton. Once I switched to a thin kerf 24t rip blade, the difference was night and day.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
Dimensions
#4 posted 01-29-2020 12:35 AM
I am using a thin kerf combo blade on the saw currently. Since its my first Forrest blade I wanted to see if they lived up to the hype before diving into the deep end and starting to switch out my current blades for premium blades. I most likely will in the future, especially for my next dado stack.
I found that slowing down a bit allowed the saw to do its thing and it didnt have any other binding issues.
pottz
#5 posted 01-29-2020 12:43 AM
- Dimensions
well thats one big problem, guys tend to push the wood faster than the blade can do it’s job.i work in the construction supply industry and i hear all the time that,the blade bogs down,or the blade warps too much,and i tell them no your forcing the wood too much,ease up and let the blade do it’s thing and it will work much better.
View sansoo22's profile
sansoo22
1907 posts in 945 days
#6 posted 01-29-2020 12:51 AM
I enjoyed the video as well. I’ve had this saw on my radar recently. My plan was to upgrade house + shop electrical in my new house then get a 220v cabinet saw. Well as life often does it threw a curve ball at me and the budget for saw and electrical had to be spent elsewhere.
Like you I’m currently using a jobsite saw and the built-ins as well as furniture I want to create are a bit bigger than that little jobsite saw wants to do. It has the power with a proper blade but it doesnt have the fence length or table top dimensions to do the job well.
I may have to really consider picking this saw up.
View Rich07081's profile
Rich07081
12 posts in 2686 days
#7 posted 01-29-2020 03:12 AM
I’ve had this saw for 3+ years & love it. I run a full kerf 40T Ridge Carbide blade & it’s sweet! If I feed it smoothly this saw & blade cut straight and the wood doesn’t burn.
For me, having the base “reversed” i.e. the caster on the left is the way to go.
Until I have the desire & time to spend many more hours in my shop and the $ for a 220v Powermatic, Unisaw, or something like a high end Grizzly the 36-725 is about right!
A solid value! Congratulations on a great addition to your shop!!!
Rich
View cmacnaughton's profile
cmacnaughton
222 posts in 935 days
#8 posted 01-29-2020 03:41 PM
- Dimensions
I ve had mine for years and it s served me very well.
- Dustin
I’ll second Dustin’s recommendation. I use a 24T thin kerf (Freud) blade and routinely rip 8/4 maple without issue. I use a combo or 80T blade for my other cuts.
Good review. I’ve had this saw since May 2019 and love it. I’ve had paint delaminate from my extension wings, but that’s the only issue I’ve had with it.
-- –Chuck M. Nutmegger by choice
View 53d's profile
53d
6 posts in 2353 days
#9 posted 01-30-2020 10:34 PM
I’ve had this saw for almost 5 years and really like it as well. The fence is great and it wasn’t too hard to adjust the blade to be parallel to the miter slots. I used to use a 50 tooth combo blade but now switch between 24t, 40t, and 80t blades. I’ve never really had the motor bog down but have had wood close up on the riving knife which just means it was doing it’s job.
Only thing I will say from your video is the riving knife needs to be in the upper position when using the blade guard :)
View nkawtg's profile
nkawtg
302 posts in 2542 days
#10 posted 01-30-2020 11:18 PM
I like mine a lot and I’m thinking of utilizing the space this saw takes up by doing this that I found on the internet.
sansoo22
#11 posted 01-30-2020 11:49 PM
I hate the internet…i feel like i cant own one of these and not do this now. Look at all the space for push sticks, push blocks, blades, feather boards, etc on that setup.
pottz
#12 posted 01-31-2020 12:46 AM
- sansoo22
that’s a great setup and really makes the saw stretch it’s limits.ive been very impressed what i got for the money.i bought mine at lowes and with the 5% discount i get plus other deals at the time it cost me 500 bucks.so if you have budget contstraint’s this saw could be the answer buddy.
View EricLew's profile
EricLew
274 posts in 2657 days
#13 posted 02-03-2020 01:07 AM
There are many of us on here that have this saw, I have had mine 5 or 6 years, and I was far from the first. It seems we all love it, I know I still do. I don’t really remember reading anyone posting anything bad about it, unless they expected more than this saw is designed to do. So I would expect you will have the same happy experience the rest of us have had. Good purchase, and Enjoy
-- I love the smell of coffee in the morning, and sawdust in the afternoon
View Dustjunkie's profile
Dustjunkie
39 posts in 665 days
#14 posted 02-12-2020 12:28 AM
I purchased this back in November last year. I am just starting out with woodworking and I wanted something that would last. After looking at all the other smaller options, for the money you cannot go wrong. I have already built a crosscut sled for it and installed the clear cut guides from JessEm.
pottz
#15 posted 02-12-2020 12:33 AM
- Dustjunkie
you wont regret it.welcome to lj’s.
showing 1 through 15 of 18 comments
