Pocket door slide as a hose holder.
Review by RobS888 posted 04-01-2019 04:48 PM 1717 views 0 times favorited 8 comments Add to Favorites Watch
Pocket door slide as a hose holder. Pocket door slide as a hose holder. Pocket door slide as a hose holder. Click the pictures to enlarge them
I purchased this a month back for $35 after seeing Rockler’s ceiling mounted slide.
I like and have a lot of Rockler stuff, but sometimes their prices are too high.
I got this aluminum pocket door slide mounted it to the ceiling in my garage:
https://www.amazon.com/gp/product/B0044FWZEQ/ref=ppx_od_dt_b_asin_title_s01?ie=UTF8&psc=1
I used rubber straps I already had to hang the hose from wheel assembly and now I can cut an 8 foot board without thinking about the hose or it snagging on every darn thing it could possibly snag on. It is smooth and needs very little to no thought when using the track saw or sanding.I was able to slide the plastic door aligners into the end of the track to act as stops, so I can’t run off the end. I paid $35, but it shows as $50 now.
Rubber straps.
https://www.amazon.com/Strap-Adjustable-Straps-Cords-Cables/dp/B003DL52LA/ref=sr_1_27?keywords=rubber+straps&qid=1554137218&s=hi&sr=1-27
-- I always knew gun nuts where afraid of something, just never thought popcorn was on the list.
View RobS888's profile
RobS888
2764 posts in 2528 days
8 comments so far
View CaptainKlutz's profile
CaptainKlutz
2714 posts in 2178 days
#1 posted 04-01-2019 05:36 PM
Cheaper is good. Looks a lot like Duratrack?
+1 Rockler Ceiling Track system is an expensive choice. Rockler didn’t innovate ceiling tracks.
Overhead track systems have been around since early 1900’s.
Unistrut is a popular version, sold everywhere.
https://www.unistrutohio.com/unistrut-trolley-systems
Duratrack is common system for hanging welding curtains and moving electrical wiring.
http://www.duratrack.com/overhead-track-trolley-systems/
Cheers!
View Redoak49's profile
Redoak49
4529 posts in 2672 days
#2 posted 04-01-2019 09:15 PM
This is an excellent idea and has many uses. I think the ceiling of a shop offers many opportunities. I have pipes across much of my shop for temporary hanging of things. But, this for a sanding vacuum hose is great.
You need to post it as a project or blog.
RobS888
#3 posted 04-01-2019 09:56 PM
- Redoak49
I had to use 6 inch spacers to clear a light fixture. the beauty is I can run the track saw without a snag on the long side or short side of my table.
View edapp's profile
edapp
340 posts in 2113 days
#4 posted 04-02-2019 12:01 PM
Great idea. I was about to purchase an articulating boom arm (like at the dentist) to accomplish the same task….
Looks like I will have some pocket door hardware on its way instead!
View Underdog's profile
Underdog
1476 posts in 2719 days
#5 posted 04-03-2019 11:12 AM
Sounds interesting. Can you show us pix of your installation?
-- Jim, Georgia, USA
RobS888
#6 posted 04-03-2019 07:49 PM
I added a couple of pictures.
I put a hook in the one support to hang the hose and power cord on.
This is almost too simple, the one thing that was a minor problem was trying to use a hook on the truck (wheel assembly) it would put pressure on the truck and lock it up, but with the rubber band thing screwed to the truck I can pull from any angle and it is fine.
View NormG's profile
NormG
6506 posts in 3687 days
#7 posted 04-14-2019 03:50 PM
Great idea, thank you for sharing this
-- Norman - I never never make a mistake, I just change the design.
RobS888
#8 posted 04-20-2019 08:28 PM
Looking Good, Can I see the process of installation it?
- erdr86
I didn’t take any pictures while installing it, but it was very easy. Let me know if there is a different view you would like to see.
