Laguna Spindle Sander SS-14 MSANOS14x14
Review by PPK posted 03-15-2019 04:37 PM 1885 views 0 times favorited 1 comment Add to Favorites Watch
Laguna Spindle Sander SS-14  MSANOS14x14 No-picture-s No-picture-s Click the pictures to enlarge them
I purchased this sander a couple months ago to replace my cheaper “many-brand” spindle sander that looks like this:
The motor had issues that caused it to overheat and stop running after about a minute of use.
Anyway, on to the review:
Pros:
-The machine is heavy and doesn’t shift/vibrate during use.
-Very quiet. Induction motor, not one of the universal (screamer) motors.
-Drums come with, and there’s a great selection, all the way down to 1/4” diameter. This is really handy for some projects with small corners.
-Steels spindles are very well machined and easy to adjust/change sanding sleeves
-Comes with stand. (Although I’m not using the stand – I like to be able to set it on my bench.)
-Table tilt is good, has good stops at 90 degrees, and locks down tightly
-Throat inserts are very heavy and seat well.
-Plenty of power. You’ll destroy your sandpaper/gum up/overheat before you’ll bog it.
-It’s all steel, with very minimal parts made of plastic.
Cons:
-Two of the drums sizes are a much softer rubber, and one of them wobbles a little bit due to the rubber. I adjusted it, but it seems to still wobble a tiny bit.
-Dust collection isn’t that great. Could easily be modified to work better with some cardboard or a chunk of PVC or something. It’s not a big deal for me, and any machine that has a tilt-top is going to have sub-par dust collection, in my opinion.
General Comments:
I got the sander a little on sale (during the Laguna Sale at the local tool store) but it runs about $500. It’s certainly not cheap, but I think this’ll be the last spindle sander I buy, unlike the $100 models.
It’s certainly an overseas product, but what isn’t? It seems to be a good one though – not like a Harbor Freight tool at all.
I can’t speak to the owner’s manual. I didn’t read it/probably wont :-) It’s not like you need to do any real assembly or anything.
The issue with the one rubber drum wobbling a little doesn’t seem big enough to reduce the 5-star rating. I’d recommend this unit to others.
-- Pete
View PPK's profile
PPK
1670 posts in 1487 days
1 comment so far
View ralbuck's profile
ralbuck
6467 posts in 2944 days
#1 posted 03-15-2019 04:49 PM
I am glad you like your newe sander.
I bought a Grizzly about 2 years ago now with the belt and spindles both. That is slightly noisy; but that is my only complaint about it!
-- Wood rescue is good for the environment and me! just rjR
