Incra - Mast-R-Lift-II-R (Rating: 5)
It came time to up my game. This is my first ever router lift after painfully manually adjustments for years. Because I have a Bench Dog table saw cast iron extension, I was limited (I believe) to either the Bench Dog router lift or Incra Mast-R-Lift-II-R . I went with the Incra because…well… what an awesome track record
What's to be said about this lift? It's awesome 5 stars. Installation was a snap. Installed a Milwaukee 3HP 5625 to ensure all routing needs would be met. All adjustments/fine tuning works exactly as you expect. Along with a Wixey router bit gauge, I tried out tongue & groove router bit set which usually would of taken me 2-4 attempts with test pieces to ensure things were set up right which means 15-30 minutes. With the adjustment capability of this router lift, was able to hit it on the nose with the first pass.
Very happy with this…expensive purchase. I used to disfavor using my manually adjustment router to the point of ever growing frustration. Now, it's a joy! Oh…and the mag lock assorted sized metal inserts… more joy!
