The Decision and Initial Setup
Review by Jerome posted 12-22-2018 03:29 AM 9086 views 1 time favorited 15 comments Add to Favorites Watch
The Decision and Initial Setup No-picture-s No-picture-s Click the pictures to enlarge them
This probably should be a blog post, but it is also a review in some way because I will explain why I chose this saw over a few others that were on the market. Often times I look for reviews, but I also wanted to share why I chose it as it does relate to how I value my purchase. This a a new saw so I want to give it its due. I currently own a JET 14 bandsaw that I purchased on CL about 5 years ago . It taught me alot as my first bandsaw, but was time for an upgrade mainly due to dust collection.
The choices were between the Rikon 10-326 and Grizzly 17’ models with cast iron wheels or better features. Initially, . i wanted was the extra 3 inches of cutting capacity to left of the blade. When I really considered the work that I do and plan on doing in the future, all I really needed was more resaw capacity than my current saw. This one has 13 inches and my old one had 6. This saw has 1 3/4 hp, and my old had 3/4hp. More importantly and also the deciding factor was dust collection. This JET has two 4”dust collection ports, compared to the 1 1/2 of my old JET 14. But it isn’t just the ports, which i will get into later.
The Rikon 10-326 was pretty darn close. It was on sale for $100 less, had the storage compartment at the bottom. The fence was not a versatile as the JET and it only had one dust collection port. The plus with the Grizzly was the 17” saw, but shipping cost and the fact that I couldn’t touch it was a big factor in my decision. I looked this saw over 3 different times , comparing it side-by-side to the Laguna 14BX, as well as others already mentioned. The steel feels heavier too. ON to the JET!
No brand loyalty here! I threw that to the side. I was a stickler for the features!
The dust port under the table was my focus, as dust piles up there. The red blade guard acts as a dust shroud and the port is directly under it. Second were two areas of “flashing” that help contain dust as the saw is running.These are located to the left and right of the upper wheel.
The JET was the only saw that covered the gap near the blade.
The Rikon had a 110v outlet, but the JET has a flip cover over the outlet.
Lastly, the comparison ended when I shook the top of the blade guard of the Rikon at it wiggled a little too much for me. I did the same with the JET and it held its ground. I inspected both up close and personal and saw that the Rikon did not have an upper guide support. The JET did, which is why it didnt move much. I took into consideration the assembly of the machine, but this was not due to user error, as I spoke with the person who put both saws together. You can barely see the upper assembly, but it is there!
The Jet also comes with a miter guage!
I picked up the mobile base from Rockler. The Bora mobile base works well with it. I had some 1/2 OSB for the saw to sit on and painted it white. Dimensions for my base are 20 3/4×28 1/8. I have three layers. The holes in the mobile base do match up with the saw, but there is a little bit more of a footprint (if you dont make new holes!)
The JET comes in two boxes: 64×27 1/2×20, and 27×20 x 17. Two employees loaded it, but I think it can be loaded into a small suv or perhaps a trunk. My neight helped me by lending his dolly. It isnt hard to move, but the box is slippery! After a few days, it was time to put it together! I took care of the base/mobile base potion first before anything. I secured it with two 3/8 lag screws and two 3/8 bolts. I’ll eventually replace the lag screws. I chose to have the lifting wheels on the back of the saw.
Once the base was taken care of, it was time for the big show, but help was nowhere to be found. I opted for the “Single Man” method! Ill give JET credit, the bulky Styrofoam was a godsend as it held up the saw with a thin board. Itfyou can somehow stack two of the foam parts and get the saw on top, it is higher than the base and it can slide on. This was not the case for me. It took a little while, but after going through my scrap wood, I found the right combination to aid the lift process. Taking pictures along the way was by far the most exhausting part of the lift! It was a good boy and stayed put. I just took my time. The breaks on the mobile base aren’t as strong as one might think, so add a stop if you take a walk on the wild side!
Conclusion
This was my first new tool purchase over a $500. My festool jigsaw was the most expensive, but thats is just because it is Festool. I digress. I’ve been looking to upgrade my bandsaw for a few years now and I finally pulled the trigger. I thought it would be a Grizzly all the way, based on the value, but I really looked at my needs. Sure, some people saw spending over 1000 on a 14 inch bandsaw is alot, considering the options. But in the end the resaw capacity, 1 3/4 HP, and dust collection were good enough for me to make the purchase. i will update my review after set-up is complete , then after a few months use. Merry Christmas to me!
12/21/2018
-- Jerome, Marietta, GA
View Jerome's profile
Jerome
163 posts in 3376 days
15 comments so far
View Wildwood's profile
Wildwood
2959 posts in 3381 days
#1 posted 12-22-2018 02:14 PM
First learn about this saw so went looking for more information ended up down loading the manual and appreciate how well it’s written. Hope you keep us informed how well saw performs.
https://content.jettools.com/assets/manuals/714401_man_EN.pdf
Thanks for sharing your set up and best of luck with new saw.
-- Bill
View JRsgarage's profile
JRsgarage
410 posts in 1756 days
#2 posted 12-22-2018 02:24 PM
Thanks for the review. Looks like you’ve made a sound choice…I also felt the Jet seemed a bit more beefier. I like that it can fit a 1” blade too. Enjoy and look forward to an update.
-- “Facts don't care about your feelings.” ..., Ben Shapiro
View MrRon's profile
MrRon
6187 posts in 4490 days
#3 posted 12-22-2018 07:22 PM
I have a Jet 3 hp cabinet saw; bought it about 30 years ago and it still runs like new. I have never really heard much negative press about Jet tools in general. That is why I place them in the same quality category as Powermatic. Delta used to be great, but not so much anymore.
runswithscissors
3134 posts in 3272 days
#4 posted 12-23-2018 12:41 AM
There’s another consideration with larger size in a BS: with the larger diameter wheels (17” or 18” vs. 14”) the blade is not stressed so much, which allows a wider blade that can be tensioned more, and is therefore better for resawing.
Jerome
#5 posted 12-23-2018 04:26 AM
There s another consideration with larger size in a BS: with the larger diameter wheels (17” or 18” vs. 14”) the blade is not stressed so much, which allows a wider blade that can be tensioned more, and is therefore better for resawing.
- runswithscissors
Interesting point! Trust me, I wanted the extra 3 inches of capacity. With that comes with a bigger footprint, more expensive blades, and more gloating! I can always upgrade again if needed.
Jerome
#6 posted 12-23-2018 04:29 AM
Thanks for the review. Looks like you ve made a sound choice…I also felt the Jet seemed a bit more beefier. I like that it can fit a 1” blade too. Enjoy and look forward to an update.
- JRsgarage
The Rikon also had 2 speeds, one was for metal. However of I put the JETon a VFD , I could slow the speed and cut metal if I wanted to.
View AHuxley's profile
AHuxley
874 posts in 4568 days
#7 posted 12-23-2018 08:39 AM
Excellent initial review, be sure to update it when you have more time using the saw, there are not a lot of reviews of this fairly new saw on the internet.
BTW you can use a VFD to control speed on a single phase motor.
View curliejones's profile
curliejones
190 posts in 3513 days
#8 posted 12-26-2018 12:34 PM
Thanks for posting this; this is exactly the decision matrix many of us face. Merry Christmas to you, Jerome, indeed! Keep us posted.
-- Like Guy Clark sez - "Sometimes I use my head, Sometimes I get a bigger hammer"
View OldMan66's profile
OldMan66
1 post in 1014 days
#9 posted 01-14-2019 02:16 PM
Hey Jerome congrats on the 14SFX. I am in the market for a new Band Saw and this unit is near the top of the list. The Grizzly G0513X2B is also right there too. Wondering if you have had a chance to resaw with this unit yet.
Any observations you ready to share?
View GR8HUNTER's profile (online now)
GR8HUNTER
9000 posts in 1959 days
#10 posted 01-14-2019 03:17 PM
GRATZ Jerome last picture look like a papa bear baby bear LOL :<))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
Jerome
#11 posted 03-04-2019 04:18 PM
- runswithscissors
I am now beginning to realize what you wrote! I am satisfied with my purchase, however, the 17” would have also been a great choice. My saw has good enough power but you cant ignore the bigger saw have the room for a bigger blade to do the work. I dont plan on resawing to the height capacity of the saw, yet.
View lui_b's profile
lui_b
3 posts in 942 days
#12 posted 03-27-2019 04:53 PM
I just purchased the same jet bandsaw from my local woodcraft and I have it for almost a month now. This is my first bandsaw and I can not compare it to others. It took me about a day and half to assemble it and needed help since it weighed about 350 pounds.
I installed a 3/4 blade for re-sawing through the course of 2 weeks and it began to make an awful noise. I immediately stopped the bandsaw and I noticed that the v-belt on the bottom pulley had inverted and were off the tracks.
I re-installed the v-belt, but by just hand turning the wheel it twists and same result. I called Jet support to help diagnose and it seems that the pulleys are slightly out of alignment. I am hoping I can fix this myself since the closes Jet service center is over 2 hours away and I not have a vehicle to transport it there.
View tvrgeek's profile
tvrgeek
2292 posts in 2896 days
#13 posted 02-11-2020 10:28 PM
This was a couple of years ago, but did you get it resolved? Once a belt rolls, it will roll again so needs to be replaced. Were the pulleys correctly aligned?
I ask as I am now in the decision process, Rikon, Laguna, or Jet as my old 10 inch Delta is even more inadequate then your old one! As the tools are so competitive, how the companies support them may be a deciding factor.
- lui_b
View jayoh's profile
jayoh
2 posts in 976 days
#14 posted 09-03-2020 12:38 PM
The lower SFPM speed is not for metal; it’s for resawing or use with thicker stock or a wider blade. The higher SFPM is for small blade widths and cutting thin stock. I notice that Alex Snodgrass from Carter guides has a new video on the JET. Not impressed with a single high-speed pulley, as many 14” bandsaws have a twin step pulley to access both speeds.
I’m seriously looking at the new Rikon 14” machine; 10-326.
View Kelly's profile
Kelly
3805 posts in 4191 days
#15 posted 11-27-2020 06:12 PM
jayoh, I bought my buddy’s 10-324 Rikon, which was a VERY low mileage beast with the plan of dedicating it to resaw, keeping my 14” Powermatic as the scroll unit, with a Carter Stabilizer.
The first thing I noticed was, the belt was running up against the housing. The next thing was, a lot of pulsing of the blade (running good 5/8” and 3/4”). The pulsing was bad enough I shut the unit down to address it and the rubbing belt problem.
Unlike my Powermatic, and I suspect the lesser expensive Jet, the lower wheel shaft is adjustable. That is the stuff of which love-hate relationships start. The love comes with being able to track the lower wheel, the hate with that you can spend a few days experimenting to get everything right.
Presuming the blades are welded well and not otherwise defective, you have four bolts and locking nuts to play with (north, south, east and west). You have to:
1) remove tension (flip the tension release lever);
2) back off all the guides;
3) loosen all the locking nuts;
4) loosen one of the four bolts to remove tension from the shaft (depending on what you are doing);
54) back off one bolt (again, depending on what you are doing) about 1/4 to 1/2 turn, keeping track of the how much you turned it;
6) turn the one directly opposite to tighten those two on the shaft;
7) tighten the first bolt you loosened to remove tension;
8) apply tension to the wheels again (flip the lever back to run position);
9) hand spin the wheels to see where the blade is tracking;
10) adjust the upper wheel to center the blade;
11) spin the blade some more and note where the lower blade is tracking;
12) go through ALL the bolt loosening, adjusting and tightening steps (left and right?) to center the blade on the lower tire; then,
13) spin the wheel to make sure the belt is tracking;
I think I want a Jet. Meanwhile, I guess I should write a review.
