Woodworking on a Half-Shoestring #79: The Dungeon Workshop - South Room Construction - Part II
Blog entry by retired_guru posted 10-15-2016 04:07 PM 2052 reads 0 times favorited 4 comments Add to Favorites Watch
« Part 78: Resurrecting a Coffin Smoother - Part II Part 79 of Woodworking on a Half-Shoestring series Part 80: The Dungeon Workshop - Clamp Rack »
The South Room will never make it in an issue of Better Homes and Gardens. For what I need, it’s coming along better than expected. I’m not done with the space.
The East (left side) and South walls are damp, even wet, all year round, so I doubt I will ever stud up a wall. I also doubt the gold colored steel cabinet will stay there. For now it keeps me from bumping my ribs or head against the capped off gas line service coming out of the wall. You can see the capped end to the left of The Washboard sitting atop of the cabinet.
The sister gold cabinet sits between the sewer pipe and bench. A good place for it. The Kobalt steel tool chest’s handle broke off, so I stripped it of it latching hardware. Now it’s a benchtop tool chest.
The shelf is as thick as you see it in this photo. Three of the five braces are on studs, so I’m comfortable with the weight of parts cabinets upon it. This bench will eventually be for electronics and scale modeling projects.
Last week I made two shelves for the bench, replaced the nailed boards top with thick, vinyl veneered particle board. Above I used two of the three Rubbermaid shelf trays I acquired from my parents, spaced out to accommodate a small shelf unit to hold empty sanitary wipe containers.
I’ve relocating materials to this space when it makes sense to do so. I’ll get the mess tamed soon enough.
-- -- Paul: jack of all dreams, a master none.
4 comments so far
View luv2learn's profile
luv2learn
3065 posts in 3078 days
#1 posted 10-15-2016 07:42 PM
You are making great progress Paul.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View retired_guru's profile
retired_guru
838 posts in 2135 days
#2 posted 10-16-2016 12:00 AM
Thanks for saying so, Lee. Today, for the first time, I saw I was winning the war. Another week and I should be able to start building projects instead of working over the shop.
View jinkyjock's profile
jinkyjock
488 posts in 2350 days
#3 posted 10-18-2016 07:47 PM
Hi Paul, been a while since I posted but looks to me as if you have made great strides.
Bet you can’t wait to make some dust.
retired_guru
#4 posted 10-21-2016 12:56 PM
Hey JinkJock! Good hear from you! And thanks.
Late this past Spring I realized I would continue to struggle with builds until the workshop was in order. It’s been a long, boring and sometimes frustrating several months getting to this point. I have a bit more construction to do before I can call it ‘done’, however, I already feel the difference and with a few small projects witnessed the ease in working compared to earlier this year. Chomping at the bit to make things? You bet! I think the time is soon. :)
