Woodworking on a Half-Shoestring #55: Seasoned Maple Boards
Blog entry by retired_guru posted 08-23-2015 11:07 PM 2297 reads 0 times favorited 9 comments Add to Favorites Watch
« Part 54: Hitachi C10FL Acquisition - Part 3 (Assembled) Part 55 of Woodworking on a Half-Shoestring series Part 56: Table Saw Adjustments and Miter Saw Station »
A couple of weeks ago I picked up twelve 8’ 4” boards (various widths and somewhere around an inch-plus in thickness) for $2.00 USD each. The seller had 18 to sell and his advertisement said must buy all. It didn’t take long to see that some were rotted completely or enough that they wouldn’t ever be useful. The twelve I found would yield a good 80% or more, so I talked him into the price each for only twelve. I didn’t think that was a bad price.
Here’s are seven of the original twelve. This gives you a good idea of which definition of ‘seasoned’ was used by the seller.
I trimmed off the rot and cross-cut boards where warpage started. Every board was thoroughly steel brushed before running through the planer. Boards over 6 ft. longer were cut in half, since there isn’t enough room in the dungeon to run a longer board through the planer.
Most of the boards were brought down to 7/8”, with some at 3/4” thickness. Some boards were cupped enough to warrant a thinner milling.
Some of the boards were heavily checked throughout the grain, yet they were quite solid. I’m sure I can find some applications for these still quite sturdy boards. Grain detail is gorgeous.
This is what is left to mill. Another day.
And these are the leftovers.
-- -- Paul: jack of all dreams, a master none.
9 comments so far
View luv2learn's profile
luv2learn
3065 posts in 3073 days
#1 posted 08-24-2015 12:43 AM
Can’t wait to see what cool projects you will create with these boards.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View MadJester's profile
MadJester
2065 posts in 3200 days
#2 posted 08-24-2015 02:27 AM
Beautiful wood….
-- Sue~ Mad Jester Woodworks, "Not what I have, but what I do is my kingdom" Thomas Carlyle
View retired_guru's profile
retired_guru
838 posts in 2129 days
#3 posted 08-24-2015 11:46 AM
Can t wait to see what cool projects you will create with these boards.
- luv2learn
My wife has asked me several times what I am going to do with the wood. I have a promised band saw box to make for a friend, long overdue, needing a contrasting color to the black cherry I will be using. If I can find a four inch section that doesn’t have any checking in it, that much is promised to be used. The extensive checking would keep these out of fine furniture. But since I don’t know how to make fine furniture, everything else is a possibility. ;)
retired_guru
#4 posted 08-24-2015 11:48 AM
Beautiful wood….
- MadJester
The grain is something else, Sue. I think I made out well this time. :)
View handsawgeek's profile
handsawgeek
663 posts in 2165 days
#5 posted 08-24-2015 01:55 PM
Hey, Paul, Nice haul (That rhymes, doesn’t it?)
I’m sure you’ll find plenty of uses for that stack. Very nice grain figure!
-- Ed
retired_guru
#6 posted 08-24-2015 02:06 PM
Hey, Paul, Nice haul (That rhymes, doesn t it?)
I m sure you ll find plenty of uses for that stack. Very nice grain figure!
- handsawgeek
Thanks, Ed. Hahaha, yes it does. :)
View jinkyjock's profile
jinkyjock
488 posts in 2344 days
#7 posted 08-25-2015 06:26 PM
Paul,
looks like a bargain, even given the checking,
and ideal for your proposed project.
As to your comment about about fine furniture making.
“Belt-Up”...... and enjoy the ride.
Cheers, Jinky (James).
jinkyjock
#8 posted 08-27-2015 06:53 PM
Paul, I was checking through my recent posts and noticed an error in my last submission.
I was trying to incorporate your comment about fine furniture making into my post,
but was unable to do so as Technology can get the better of me.
And I appear to have deleted a full sentence from my post.
It should read;
“As to your comment about fine furniture making.
The steps you have taken recently are leading you down that road.
“Belt-Up”......and enjoy the ride.
I hope that makes more sense.
P.S. I will use the Preview option more often in future.
retired_guru
#9 posted 08-28-2015 12:43 AM
It should read;
- jinkyjock
Jinky, I always appreciate your interaction and comments left on my posts. I have a lot of pressures here, some having nothing to do with woodworking, and in the end, I need to ‘suck it up, Marine!’ ;)
