Woodworking on a Half-Shoestring #43: Tool Tip - Simple Depth Gauge for Twist Bits
Blog entry by retired_guru posted 05-25-2015 11:53 AM 1250 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 42: Beefing Up A HF Windsor-Style Workbench Part 43 of Woodworking on a Half-Shoestring series Part 44: Franken-Rack gives life to Harbor Freight trailer »
Yesterday, while working on the stake sides for my Harbor Freight trailer, I found myself in a need for a depth gauge for the drill bits I was using. I didn’t think to bring out a roll of painter’s tape and I was too into my work to get one from the dungeon.
A solution that worked well for me: use your marking pencil to draw a heavy line across one of the twist bit’s flukes. The line will be quite visible as the bit spins.
_
I have been busy with building a trailer (to haul lumber and everything else), as well as organizing the dungeon workshop, and most recently, setting up the potted pallet garden in our back yard. Once the trailer is done, I will make a project post with pictures. Until then, I will catch up with everyone as soon as I can.
-- -- Paul: jack of all dreams, a master none.
0 comments so far
