Woodworking on a Half-Shoestring #21: Dungeon Gets A Lumber Rack
Blog entry by retired_guru posted 11-21-2014 01:22 PM 3822 reads 0 times favorited 6 comments Add to Favorites Watch
« Part 20: Dust Collection Finally Up and Running! Part 21 of Woodworking on a Half-Shoestring series Part 22: Upcycling Old Furniture for the Dungeon »
A couple of days ago I started on a wall-mounted lumber rack in the dungeon. At that time I had barely enough room to get around the Black and Decker Power Mate and various stuff laying around, including the destructed pallet wood I had in various piles on the floor. Here is what my workspace looked like while I was constructing the rack:
Because of the limited space, I didn’t want to use the miter saw in this project. This past summer I bought a Stanley FatMax cross-cut hand saw, the perfect solution in this project:
The brownish-red coloring on the tip of the blade is reflective of the camera’s flash and dungeon lighting. Even after all the cutting, the blade is shiny and pitch-black from tip to handle. You can see how aggressive the teeth are on this saw. I’m sure I could prune trees with it. If you are in need of an aggressive saw that will cut straight and easy through any kind of wood, this would be a good recommendation.
Here is the finished lumber rack, along with close-ups of the arms and braces. It’s in a good location. The support posts ruin the space for much of anything other than storage:
I came up with specific dimensions for this project, like the length of the arms are 16” and the braces are all patterned after the first one installed. Different thicknesses and even kinds of wood were used, so I compensated as required:
And here is the rack loaded with the wood I had piled on the floor:
Getting the lumber off the floor and pushing some things to the sides, you can see I have a lot more space to work with now. This is only the start. Once I get the bicycle shop end organized, the dungeon will be a multi-purpose shop for all my interests and needs:
Conclusion:
I spent a lot more time in making this rack than I had planned for. The constant search for materials and tools needed always eats up a lot of time. Once I found everything, it was a matter of finding the right dimensions from the wood pile, measuring what I needed, clamping the stock to the top of the Power Mate and sawing as straight as possible, then dry fitting with two levels before tacking with the nail gun. Once tacked, I drilled pilot holes and fastened with the appropriate screws. Leveling added extra time and effort because most of the time I had to drill the minimum amount of holes to allow alignment, fasten, then drill the rest and finish fastening. Unfortunately, I only have one portable drill heavy enough for this kind of work, so I had to switch between drill and screw bit every time. The Kobalt Speedbit set was some help, but they are so flimsy I ended up breaking the bit midway into the project, and the quick-change unit added so much length to the business end that it made it difficult to get in between the wall studs. I eventually gave up on the system and resorted to changing bits as needed. My next new tool purchase will be for another portable drill.
-- -- Paul: jack of all dreams, a master none.
6 comments so far
View luv2learn's profile
luv2learn
3066 posts in 3081 days
#1 posted 11-21-2014 04:36 PM
Wow Paul, what an improvement. Organization always takes time up front but saves time in the long term. Great job.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View handsawgeek's profile
handsawgeek
663 posts in 2173 days
#2 posted 11-21-2014 08:04 PM
Most excellent !! It’s always nice to get things organized and make room for projects. Looks like you have a pretty nice shop space going there. I look forward to seeing it evolves in the future.
-- Ed
View retired_guru's profile
retired_guru
838 posts in 2137 days
#3 posted 11-23-2014 01:44 PM
- luv2learn
Thanks! Organizing, in my situation, means making storage and benches as I go. It is taking a lot of time to get what appears to be so little done. But if I don’t do this now, I know what the results will be. I know how it will affect my desire to work in the dungeon and the workmanship I produce. It’s also the best time to hone my construction skills. I can get away with some sloppy learning here. ;)
retired_guru
#4 posted 11-23-2014 01:46 PM
Most excellent !! It s always nice to get things organized and make room for projects. Looks like you have a pretty nice shop space going there. I look forward to seeing it evolves in the future.
- handsawgeek
Thanks! I think the shop will come together okay. The challenges I gave to work with are severe ones, like the crumbling, broken up concrete floor, which makes it impossible to roll anything on it. I’m hoping that once things are where they need to be I can patch it up in small sections at a time. It gets better as I get things done. :)
View shawnSK's profile
shawnSK
39 posts in 137 days
#5 posted 03-28-2020 04:21 PM
Hi Paul, I read some of your recent posts and thought I’d start way back at the beginning. I haven’t skipped ahead, but the Dungeon looks promising. It’s been neat to see how you are reclaiming that space. Also, based on your drill press clamp review I bought a couple and they add some nice versatility to my Workmate.
-- Shawn, Saskatchewan
retired_guru
#6 posted 03-28-2020 06:48 PM
Hi Paul, I read some of your recent posts and thought I d start way back at the beginning. I haven t skipped ahead, but the Dungeon looks promising. It s been neat to see how you are reclaiming that space. Also, based on your drill press clamp review I bought a couple and they add some nice versatility to my Workmate.
- shawnSK
Hi Shawn! Thanks for taking a look through my past posts. If you’re willing to dredge that deep, you will be surprised to see how much The Dungeon has changed since I started this profile and blog series. I’ve been deep re-organizing with construction in the workshop since last fall. I should have most of it done in a week or two (sans the North room, which requires some good weather days to remove heavy junk wood destined for the landfill) and will post a walk-around then. Of course, it will always be The Dungeon no matter what I do to it. :)
I’m glad you could find a use for the tip on the HF drill press clamps. This summer I will be replacing the wood jaws on my outdoor Workmate, so I’ll see first-hand how they work.
