Woodworking on a Half-Shoestring #121: Creamer and Sugar Bowl Carrier - Build Progress
Blog entry by retired_guru posted 04-30-2020 12:27 PM 181 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 120: Dungeon Workshop Walkaround Tour - Spring 2020 Part 121 of Woodworking on a Half-Shoestring series Part 122: Candy Jar Rack - Prototyping »
With the workshop mostly reorganized, I’ve started to get at projects already started and on my To-Do list. A simple project I had been putting off was a small carrier for our Nortake creamer and sugar bowl set. The design is similar to the one used in the salt and pepper mill carrier I made a few years back.
The design incorporates two different size boards glue together to give the top ledge look, which also simplifies the build process by using a hole in the top board to create a recess once the boards are laminated together. I’ve included the salt and pepper mill carrier pics. Both carriers will be side-by-side on our kitchen table.
I used red oak for this project, to match the wood used in the salt and pepper mill carrier. As with the previous project, the oak is from a pallet I deconstructed a few years back.
The holes made in the top board were of two different dimensions, both larger than the largest Forstner bit I owned. I bored a couple of holes large enough for a clean-cut jigsaw blade to fit and removed the waste accordingly. A little time on the oscillating sander cleaned up the circumferences.
It was at this point in the construction that I realized I didn’t prepare for the chamfering of the holes to accommodate the sloped bottoms of the creamer and sugar bowl. There were only two options that made sense: 1) make a router template and use a trim router with a top bearing 45 degree bit to bevel the holes, 2) mark the dimensions for the chamfers and remove the waste with a rasp. I opted to use the rasp. I added a small indent for the creamer handle. When finished, the boards were joined with Titebond I PVA glue.
A pretty good fit. Should be just enough play to deal with humidity changes in the kitchen.
As long as the router was being shunned, I decided to use a block plane to create the 45 degree chamfers on the top edges. I knocked off the opposing corners before skewing the block plane across both ends to eliminate blow out.
I have to say, I was impressed with how well the first chamfer went, since I didn’t make an effort to sharpen or hone the iron beforehand.
With all four chamfers done, sanding, sealing, and top coat finishing is left.
The salt and pepper mill carrier was finished with spray shellac. Because this carrier will have the potential to receive milk spills, I will be top coating with Minwax Polycrylic instead.
Here is what the salt and pepper mill carrier looks like. I’m sure I posted this here before.
I will post the finished build as a Project.
-- -- Paul: jack of all dreams, a master none.
2 comments so far
View luv2learn's profile
luv2learn
3066 posts in 3080 days
#1 posted 04-30-2020 01:49 PM
Nicely done Paul. I like the simplicity of your design.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View retired_guru's profile
retired_guru
838 posts in 2137 days
#2 posted 04-30-2020 03:40 PM
Thanks, Lee. I enjoyed using rasps and a plane in this project. Always more satisfying when I use hand tools..
