Woodworking on a Half-Shoestring #96: Progress: Raised Dog Bowl Holders
Blog entry by retired_guru posted 12-12-2018 11:17 PM 665 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 95: Prototyping a Christmas Gift Part 96 of Woodworking on a Half-Shoestring series Part 97: Progress: Raised Dog Bowl Holders & Minecraft CircleGuideKit Review »
I promised my youngest daughter for Christmas raised dog bowl holders for her two dogs. These are based on plans from Build Something. I posted in an earlier blog entry the prototype I built using vinyl-laminated chipboard and pine studs for the legs. You can see it in the picture, in front of the unfinished units. You may notice the two new units are longer and wider (an inch both ways) than the prototype, which was designed for a smaller bowl than I am going to use.
Originally, I was going to use reclaimed oak throughout, but instead went with 3/4” oak veneer plywood for the front, sides, and top. One half sheet makes two dog bowl holders and leaves a little bit of usable waste. White and red oak is used for the trim and legs.
Two 7-5/8” holes need to be cut out of each top piece for the bowls. I also need to rip thin oak strips to add as a boarder to the plywood top. Pocket hole joinery makes this a quick build, but would cause wood movement issues if I had gone with solid wood, hense the switch to plywood.
My daughter wants them finished in a dark stain. I will probably go with Kona or Espresso, then poly for the topcoat. The joinery simplifies finishing, by sanding and finishing the bases and tops separately, before assembling. A good thing, because Christmas is fast approaching, and we all know finishes take forever to dry when we are in a hurry.
I’m sure she’ll be happy with them. Laszlo and Louis…well, they are always happy when I am around, so it doesn’t matter what they think.
-- -- Paul: jack of all dreams, a master none.
2 comments so far
View luv2learn's profile
luv2learn
3065 posts in 3073 days
#1 posted 12-13-2018 10:36 PM
Nicely done Paul. The pups will enjoy them for sure.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View retired_guru's profile
retired_guru
838 posts in 2129 days
#2 posted 12-14-2018 02:22 AM
- luv2learn
Thanks, Lee. I’m looking forward to seeing how these hold up under use. Laszlo and Louis are a handful and a half.
