All Replies on Aniline Dye on Woodturning Pen
View Shaun's profile
by Shaun
posted 08-21-2017 05:36 PM
9 replies so far
View TheDane's profile
TheDane
5846 posts in 4508 days
#1 posted 08-21-2017 05:57 PM
Here’s a video that shows how one dye manufacturer (KEDA) applies dye to quilted maple: https://youtu.be/m0T1T_CpzlY
View bigJohninvegas's profile
bigJohninvegas
802 posts in 2307 days
#2 posted 08-21-2017 06:22 PM
check out spirit stains, alcohol based and dry almost instant.
https://www.woodturnerscatalog.com/p/148/6338/Chestnut-Spirit-Stain
colors blend easy too. alcohol base, even if it drys. you touch another color and it will blend. really fun to work with.
-- John
Shaun
39 posts in 1275 days
#3 posted 08-21-2017 09:01 PM
Thanks, guys – that’s great information.
I’ve reached out to both suppliers (Chestnut and KEDA) to ask them some questions relevant to applying dye on the lathe. I’m also looking for suppliers in Canada. Chestnut doesn’t seem to be available to me at all but KEDA seems to be reasonable for shipping from the US.
The youtube video was quite helpful. I watched 2 or 3 of the KEDA videos and it gave me some good ideas about layering different colours to make the grain REALLY pop.
-- Shaun, Ontario, Total n00b at wood turning
TheDane
#4 posted 08-21-2017 10:18 PM
FWIW … I have been using KEDA dyes for 3 or 4 years now, and have been very happy with the results. Maybe I should do a review.
I’m not sure about how color-fast they are, but I haven’t seen any changes in the pieces I have dyed over the years.
I always use alcohol (DNA), but KEDA uses rubbing alcohol because doesn’t evaporate quite as fast … he says better for blending.
View jwisbey's profile
jwisbey
35 posts in 3259 days
#5 posted 08-22-2017 01:54 PM
I used full strength Trans Tint red on this pen made from tiger maple. Kept the pen spinning for 2 minutes then applied several coats of CA. A little of the dye came off with the first coat of CA, but it was not a noticeable change in appearance on the pen.
View gwilki's profile
gwilki
357 posts in 2319 days
#6 posted 08-22-2017 03:56 PM
I’ve used the powdered aniline dyes from lee valley, mixing with alcohol instead of water, with good results. They dry pretty much as they are going on.
-- Grant Wilkinson, Ottawa ON
Shaun
#7 posted 08-23-2017 05:41 PM
TheDane:
I’ve been in touch over email with Keith from KEDA and he was pretty helpful. He recommended the liquid dyes mixed with alcohol for an the almost instant dry I’m after. Trouble is, his liquid dyes aren’t available to me in Canada.
Have you been using liquid or powder? I can get his powdered dyes in Canada and mix them with alcohol.
jwisbey:
What you’ve done with that pen is exactly what I’m after. And I’m happy to leave it spinning for a mere 2 minutes! :-)
When you say “full strength”, do you mean you didn’t cut the liquid dye at all (i.e. used it as the concentrate) or that you mixed it at the recommended full strength?
Trans Tint isn’t available to me in Canada but the former Trans Tint supplier now has something called ColorFX dyes. From what I’ve read, they are essentially the same. The link is here:
http://www.woodessence.com/ColorFX-Dye-Concentrates-C12.aspx
gwilki:
That’s great to know. I do get to Lee Valley often enough. It could be worth trying them as well. The colours on the Lee Valley website look pretty dull but it may just be that they didn’t do the best presentation with their dyes.
TheDane
#8 posted 08-23-2017 10:38 PM
I use their powdered dyes and mix myself with alcohol.
gwilki
#9 posted 08-24-2017 05:55 PM
Shaun: The aniline dyes looks quite dull when they dry. When you put a finish on them, they pop. I believe that the ones you want are what LV calls aniline mixing colour. You can mix different colours together to get pretty much any colour you want. The more powder to alcohol, the deeper the colour.
