All Replies on How would one do this through joint
View Eugd's profile
by Eugd
posted 09-02-2016 05:20 PM
16 replies so far
View RogerM's profile
RogerM
807 posts in 3485 days
#1 posted 09-02-2016 05:23 PM
Picture???
-- Roger M, Aiken, SC
View Eugd's profile
Eugd
65 posts in 2197 days
#2 posted 09-02-2016 05:58 PM
View gargey's profile
gargey
1013 posts in 1861 days
#3 posted 09-02-2016 06:01 PM
That table is gross.
It could be faked joinery. The lighter piece of wood could actually be cut into 3 pieces. Or the vertical legs could be cut into two halves and glued back together.
View ChefHDAN's profile
ChefHDAN
1805 posts in 3935 days
#4 posted 09-02-2016 06:12 PM
Yep, can’t be three pieces of solid wood. There’s lots of YouTube content for Japanese Joinery that can give you some similar ideas if that design style appeals to you.
View Eugd's profile
Eugd
#5 posted 09-02-2016 06:26 PM
Thanks for the info, I was thinking it something had a be cut and glued, would it be easier to cut the sides in half then do it?
View diverlloyd's profile
diverlloyd
4113 posts in 2943 days
#6 posted 09-02-2016 07:57 PM
It would look better from the side if it was cut half way down on the leg pieces and the center piece that would also make it easier to put together also.
View Woodknack's profile
Woodknack
13557 posts in 3466 days
#7 posted 09-02-2016 09:00 PM
I can think of two easy ways and several complicated ways to build what I can see but I’m seeing only one angle. Post a link.
View joey502's profile
joey502
558 posts in 2604 days
#8 posted 09-03-2016 01:28 AM
Based on pic. I would cut the legs in half at the center of the stretcher. The legs and stretcher would be notched into mating parts. Then glue the legs back with the stretcher in place.
joey502
#9 posted 09-03-2016 01:29 AM
On second thought you could make the stretcher in 3 pieces and use dowels or floating tenons to overcome endgrain glue up problems.
View 000's profile
000
2859 posts in 1985 days
#10 posted 09-03-2016 01:37 AM
What I see is that the stretcher is cut into 3 pieces.
The center is attached between the 2 legs and the ends of the stretcher are attached to the outside of the legs.
No through tenon from what I see. Look at the radius of the arch, it’s not consistent, you can tell the ends were cut off and moved to the outside of the legs.
Not how I would do it, but that’s how it looks like it was done to me.
Woodknack
#11 posted 09-03-2016 03:58 AM
https://www.etsy.com/shop/MokuzaiFurniture?ref=l2-shopheader-name
Right click and open pics in a new tab to see the whole thing.
View Eugd's profile
Eugd
#12 posted 09-03-2016 04:18 AM
Thanks for all the info, it’s not my cup of tea either, but it’s what she wants, so I’ll try to make
View ste6168's profile
ste6168
259 posts in 2257 days
#13 posted 09-03-2016 01:30 PM
Ill have to agree with the first comment, that table looks awful. Certainly not a true through tenon, not possible.
If I were to do it, I would rip the legs down the center, cut the notches, and glue it back together. Another way, as others side, would be cut the stretcher into three chunks and glue it up that way. Another way, much more challenging, would be to create and actual through-tenon, that goes all the way though the legs and into the end cap, which would have a mortise to mate there.
View 000's profile
000
#14 posted 09-03-2016 02:10 PM
I think splitting the legs in half would be best, but here is another way.
Cut the mortise in the legs for the through tenon.
Make the stretcher then rip however much you need off the top of it in order to slide it through the mortise.
Then slide the top piece that you ripped off of it through and glue it back on.
View GR8HUNTER's profile (online now)
GR8HUNTER
8427 posts in 1798 days
#15 posted 09-03-2016 02:36 PM
3 separate pieces
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View Mike_D_S's profile
Mike_D_S
711 posts in 3300 days
#16 posted 09-04-2016 03:21 PM
I think if I would do it, then Jbay has the right method. Following his method, you could notch the bottom piece for the legs so when the top strip is slid in you have the legs locked in place without any special joinery.
Mike
-- No honey, that's not new, I've had that forever......
