All Replies on Filter sheet in Thien Baffle lid
View Bdobs13's profile
by Bdobs13
posted 09-01-2016 12:23 PM
5 replies so far
View Bill7255's profile
Bill7255
428 posts in 3172 days
#1 posted 09-01-2016 12:41 PM
For a shop vac system I wouldn’t use a Thien baffle system. Get the small dust deputy. I have one on my system used mainly for my sander. Very little dust gets by the cyclone. I do have the drywall bag and HEPA filter, but with the Dust a Deputy it is still almost empty after more than a years use of my sander. I have emptied the 10 gal bin twice.
-- Bill R
Bdobs13
13 posts in 1520 days
#2 posted 09-01-2016 04:37 PM
Thanks for the reply Bill, I would love to get the dust deputy but cost is the issue where I can build the diy dust separator for basically free. The dust deputy would be super convenient and easy to install so it is tempting…
-- 15 hours of youtube tutorials and research for my 20 min project...might need to rethink this...be back in 15 hours
View clin's profile
clin
1121 posts in 1883 days
#3 posted 09-01-2016 08:40 PM
You can’t replace a bag with a small patch of bag material and expect it to work very long. The bags have probably several hundred times more surface area. The way I see it, if you have enough dust that you need the filter, a filter the size of the hose (small area) will simply clog up very quickly.
I happen to be one of those with the Dust Deputy, bag filter and HEPA filter. It works very well.
In your case, I think you either get the Dust Deputy, no bag and still use the HEPA filter. I get very little material in my bag, so it likely is not critical to have one.
The other choice, is get a new shop vac that will accept a bag, and keep the Thien baffle you have.
I think the Dust Deputy is the better choice since you really won’t need to change out the bag. One less thing to have to mess with, and no added cost replacing bags.
I think you can get a bare bones Dust Deputy and mount it to your own container and save a few dollars.
The Dust Deputies really work amazingly well.
-- Clin
View MT_Stringer's profile
MT_Stringer
3183 posts in 4118 days
#4 posted 09-01-2016 09:06 PM
+1 on the Dust Deputy. It works great. I’ve had one for several years. Forgot to check the 5 gal bucket and discovered it completely full. The Rigid shop vac was empty and no dust on the filter, or in the bag. Guess I lucked out this time.
I have a manifold to hook up to my miter saw, bench top belt sander, ROS sander via hose, Kreg pocket hole jig (via hose) and router table (via hose).
Under $50 for an excellent working dust collector.
http://www.woodcraft.com/Product/149952/Molded-Plastic-DIY-Dust-Deputy.aspx?gclid=Cj0KEQjwo5--BRCS8ceLjv-XppUBEiQAGp15EHzqrQewWUOdie_NJu5AJuAIK_89wnQDbizFVsurMfkaAmrS8P8HAQ
Here is a picture of my original set up with a Shop Vac from Lowe’s.
Bdobs13
#5 posted 09-02-2016 10:43 AM
Thanks for the advice Clin and MT_Stringer. MT, that setup you have a picture of is the $100 dust deputy which would be nice and the stand alone with just the “cone” is $50 which would then need another $20 or so to be complete but again it has the issue of price. I had the option of this or a real respirator and chose the respirator with quality filters. I was really hoping to find someone that may have tried the dust bag stopper on the outlet of a diy dust separator. End of the day I might need to save money to pony up with the dust deputy but was really hoping someone had tried this experiment. Again thank you all for the comments.
