A Project for June.. #14: Jointer Work, and a glue up...
Blog entry by bandit571 posted 06-19-2022 03:44 PM 701 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 13: Clean up, start on lid Part 14 of A Project for June.. series Part 15: More lid work, start on a collar »
When last seen, these 3 panels..
Were in need of a Jointer being run along all 6 edges….as I hadn’t decided which edge goes against which edge…Picked out the showiest plank, and called it the “Center”....
These are 1×6 x 36” planks….might as well get out the big, cordless Jointer….plane.
Stanley No. 8c…
I have a 36” long Lufkin Tinner’s Rule….makes a nice straightedge….checking for both high and low spots….I also checked for the edge being square..
Spent a half hour in the shop the other evening….got the center board all jointed on both edges….then, this morning,,,worked on the other 4 edges…even found some spalt..
May set this edge against the center board?
Center is the one on top…..which left the other plank to joint..
I do both edges, because I’m never sure which edge will go where….was a very busy morning..
For about half an hour’s work….then the glue, cauls and clamps ( in that order)showed up..
Cauls on the ends helped hold the upper 2 planks still, while I applied the clamps….
Lower joint was more into a “Rubbed Joint” upper was a bit sloppy…..let this sit a day or 2….need to free up the tablesaw, again, anyway….need to mill the lid’s collar parts, to house a large, raised panel….
Stay tuned..
1 comment so far
View MrWolfe's profile
MrWolfe
1972 posts in 1615 days
#1 posted 06-19-2022 04:43 PM
Great blog.
I don’t always comment but I always read your blog posts. Excellent pics and process steps. You are keeping traditions alive and demonstrating some serious wood working skills. And your projects are always well done.
Thanks.
