Aromatic Red Cedar Box, from scraps #5: getting the tray..done
Blog entry by bandit571 posted 01-07-2022 11:16 PM 500 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 4: Hardware, re-do a lid, start on the tray Part 5 of Aromatic Red Cedar Box, from scraps series no next part
Was not the easiest thing….thought I could hand saw the fingers….saw wasn’t fine enough…moved over to the bandsaw…
Had just started on the other end of this side piece…..BANG! Blade in the bandsaw broke…grrrr. Had a scroll saw around the shop, somewhere….hmm…
Used the first set of fingers as a pattern..
Hmm, might just work…got the other 3 corners done..
Tested the fit to the base/bottom ….next, a handle
Scroll saw was still on the bench, and one more task before I put it back on the shelf..
Handle needed fingers on each end…to fit into a couple through mortises…
Was finally able to get some glue and clamps done..
Let this sit a day, then glue on the bottom…
Let that sit a day…came back today…put all the clamps away…
Long sides were cleaned up, ends were sanded flush…areas a plane couldn’t reach..
Ok…Box needed 2 strips glued into the bottom…makes 3 compartments, and..
A place for the tray to sit on..
And we have a Padlock? I guess this little Project is done..
Thanks for looking in…
1 comment so far
View Dave Polaschek's profile
Dave Polaschek
10237 posts in 2032 days
#1 posted 01-08-2022 01:48 AM
Cute little box, Bandit!
-- Dave - Santa Fe
