Fancy Corners, for a box #5: Bad lid, good lid
Blog entry by bandit571 posted 10-23-2021 01:37 AM 895 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 4: try herding cats? Part 5 of Fancy Corners, for a box series Part 6: Started on the hinges, at least »
The more I looked at that lid…the less I liked it. Even a coat of stain didn’t help all that much..
Giving off “Casket” vibes….did NOT really fit the rebates , either…
In the Dungeon Shop, we try to be “Mistake-free” so, any mistakes are very soon headed to the Fire Pit…Lid was too thick, rebates weren’t right…removed both…rebates took a couple passes, being stubborn?
And a second try…
Was taking a blade with at a time. Even removed the way too big beveled edges….will start over.
Resawn Ash was cut to almost the right size….made into a glue-up..as one strip was too narrow…
Let that sit a day, or so…clamps came off ( SLOWLY…) this evening…panel needed a little work..
Millers Falls No. 15 Jumbo Jack seemed to be available….got fairly close to flat…
Squared the ends a bit better….
Found some better hinges to use. Decided a small bevel around the top of the box might work….trimmed the panel to fit the bevels….corners needed a miter..
To better show off the spline’s beads….had a couple high spots….only way to remove those?
Millers Falls No. 9 smoother…
Knee said it was time to stop….went back upstairs, try again tomorrow….
Stay tuned…
1 comment so far
View robscastle's profile
robscastle
8291 posts in 3486 days
#1 posted 10-25-2021 05:33 AM
Come on Bandit, we have all got to go sometime.
-- Regards Rob
