July, Frame & Panel Box Project #8: Lid attached, started on a finish (no stain, this time..)
Blog entry by bandit571 posted 07-18-2021 02:38 PM 411 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 7: Bottom installed, lid into the clamps Part 8 of July, Frame & Panel Box Project series no next part
Ok..Box first…front and back bottom rails sit lower then the ends do…one is really low down…got out 2 routers..
The Craftsman has a round-over bit…the DeWalt #610 has a edge trimmer…because the bit has a 1/2” shank.
Between the two…
Was able to match the ends to the front and back bottom rails…next, needed to round that lid a bit..
Along the ends… and..
Along the front and back of the lid’s top edges..and any spots I might have missed…
Next…the one operation I do not like…mortising hinges…..something always goes wrong…no matter how well I doa layout…
Or, how well I chop…
Either the lid, or the box…
Something always wants to fight…..like a hinge that will jump off the mortise, and go hide out on the floor…knowing full well I do NOT have a replacement for it…..swept the floor, looking for the shine of Brass..
having issues with screws..didn’t snap any, this time….stripped more than a few heads out, though…yes, I even waxed the threads first…
Get the hinges attached to the box, first….then find a way to add the lid….got one screw into each hinge, then clamped things up…
Then add a latch…
Smaller screws, better pilot hole drill bit ( nail)...better driver…MORE WAX! an set this on the now cleared off bench…
Dug out a can, and a Church Key…
And a cheap brush…
And give the box a coat (or 3) of Amber Shellac….
As to what will go inside the box?
I have 4 spokeshaves that could use something better than hanging on a nail, somewhere…
Need to build a rack to hold these….that will be in the next episode
Stay tuned
2 comments so far
View Dave Polaschek's profile
Dave Polaschek
7954 posts in 1741 days
#1 posted 07-18-2021 03:12 PM
That’s turning into a pretty little box, Bandit!
For screws for hinges, I have a handful of #0, #1, and #2 steel screws that I use to make the pilot holes for the next bigger size of brass screws. Takes more time, but I haven’t snapped off a brass screw or stripped a slot in a couple months.
-- Dave - Santa Fe
View robscastle's profile
robscastle
8094 posts in 3362 days
#2 posted 07-21-2021 09:47 PM
Excellent result Bandit
Nice to see you letting the machines to do the work for you at last.
Now with a suitable template you can use your trimmer to to hinge morticing too! and a square corner chisel to finish off, or as some hinges have rounded edges now the mortice is dine in one hit.
Are you planning on making some wagon wheels?
-- Regards Rob
