June 2021, leftover scraps of Ash, Box Project, maybe #2: Bring on the planes
Blog entry by bandit571 posted 06-08-2021 10:10 PM 335 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 1: Resaw work to start Part 2 of June 2021, leftover scraps of Ash, Box Project, maybe series Part 3: Started on the corners »
Time to flatten the boards a bit..
Clamped the narrower of the longer boards into the vise…run a jack plane across to knock down the high spots..
A “Before & After”....and then after the other half was done…
Not too bad?
Set #2?!
https://s3.amazonaws.com/vs-lumberjocks.com/quel2cp.jpg!
Jointed the edges a bit..
There was a beltsander in use, as well…
Set #3 took a bit more work…
Decided to use the tablesaw, and trim this up as a 4-square,,,before I went too much farther..
Then each went in to the vise for a bit…
Finally, was able to line both up..
I still think this is better than driving down to Lowes, and buying their over-priced “Project Boards” besides, they don’t carry Ash.
Next up? Transform 4 of these into a box…that’s next time…
Stay tuned…
0 comments so far
