A Table for the Gazebo #5: Mortises, two ways
Blog entry by bandit571 posted 05-21-2021 07:03 PM 486 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 4: Aprons? Part 5 of A Table for the Gazebo series Part 6: Rest of the mortises, and a glue up, finally »
Well, I was going to do Olde School and chisel/chop them out..
Was taking way too long…Thought there MIGHT be a quicker way….Seems the tenons are 3/8” thick….hmmm
I do have a decently sharp 3/8” Forstner bit….I’d still have to lay out the mortises the same way….then clean the mortise out with a chisel..
Seemed to go a little quicker…..like about 3 this way, to 1 the other way….able to get a few dry fits, too…
Even to the point that clamps (no glue..) got involved..
Needed to size the drawer front….along with it’s 4 tenons..
Need to drill/chop out the matching mortises…next time in the shop….
hauled a 1×6 x 8’ pine plank to the shop…..needed 2 slabs for the sides of the drawer..
D-112 to make a few cuts….along with the back of the drawer..
Reset the rip fence…need to rip the 1×6 down to match the height of the drawer front…
Have plans for the waste cuts….
Longer 2 will get notched to fit around the legs…and be runners for the drawer to slide on…the other 2?
Trying to avoid them knots….will get out the mitersaw and cut a few (4) corner blocks…( may need a couple more?)
Corner blocks…glued and screwed into the corners, then a slotted hole to attach the table top..
IF I can cut them close to perfect…they will also pull the corners square…Mitersaw?
One of them Cordless Stanley No. 346 models…..
Stay tuned…waiting on the shop to cool down…
1 comment so far
View robscastle's profile
robscastle
8542 posts in 3657 days
#1 posted 05-21-2021 09:33 PM
OMG Bandit I actually used to have one of those models!
BTW HCM the most almost under used Tool in the workshop.
You know its the first tool I would sell, ... only problem is no sooner I did so I would like to build a nice table like yours.
Excellent work, ...keep it up!
-- Regards Rob
