Had a stash of Ash scraps to process….some wound up right in the burn pile…others were resawn dow to 1/2” thick…
Some were ripped down a bit….as 6” wide stuff was a bit rough to resaw….with a 8” tablesaw….
And there was a stash of very thin cut-offs…..tray dividers?
maybe some for a lid? used a jointer plane, to make a few glue joints fit better..
had a few boards that were a tad uneven…thickness wise…ran them through again to remove the excess thin stuff…had one such strip fall over, just barely catch the saw blade….and come flying back at me…
And bounced off of me stiff upper lip…
Anyhoo..this is the last of the panels that was glued up…
Out of 4 panels. letting these sit a while…maybe they will stay flat?
Finger/box joints to connect these into a box of some sort,,,,add a bottom and a lid…and a tray I can lift out
Stay tuned..
6 comments so far
Dave Polaschek
home | projects | blog
6673 posts in 1558 days
#1 posted 11-30-2020 01:36 AM
Quarter inch ash, if it’s straight, can make nice little drawers. Or tiny boxes. I’ve even used 3/16, though that’s about the smallest I generally work with except as a floating panel…
-- Dave - Santa Fe
Sylvain
1169 posts in 3475 days
#2 posted 11-30-2020 09:06 AM
- You could have used the bandsaw for resawing.
- when assembled in the form of a box, wood has a lot of strength. A six bottle French wine crate (nailed) is made ou of 3/8” maritime pine for the sides and 1/4” for the bottom and top. Six bottle is about 16~17 Lb.
Although I would not put 16 Lb on a 1/4” shelf.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
bandit571
27523 posts in 3659 days
#3 posted 11-30-2020 11:42 PM
Since today is Monday…shop was closed, today. Will try to start back in Tuesday…I hope. Too many errands to run, today…..
Bandsaw I have does not do resaw very well….even worse with the 3/16” blade I have in it…..
I like working with 3/8” thick Ash….even better when it is 1/2” thick….1/4” is about as thin as I like to go…
Foghorn
929 posts in 362 days
#4 posted 12-01-2020 01:42 AM
I can’t believe you didn’t break out the bowsaw for this Bandit! :)
-- Darrel
bandit571
#5 posted 12-01-2020 01:56 AM
It’s a 9ppi cross cut saw….not quite a rip saw.
Maybe some other time?
Foghorn
#6 posted 12-01-2020 03:52 PM
A beauty!
-- Darrel
