Blanket Chest Project #4: Day #4
Blog entry by bandit571 posted 11-07-2020 03:30 AM 481 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 3: day 3, all 2 hours worth Part 4 of Blanket Chest Project series Part 5: Day #5...meh »
another 2 hours worth….sharpened the mortise chisel…and put it back to work..
The bevel had become rounded a bit,,,,flattened that back out…
Seems to work much better, now….I also changed the bandsaw blade..old one was getting a bit too dull, was burning the wood, more than just making a cut..cuts better, now
Only had 3 mortises to do…
Then I could stash the last frame over by the first 3 frames..
2 end frames, a front and a back frame…time to bring a few boards down to the shop..one didn’t look all the bad..
But the one behind it had a lot of knotty problems….BIG knot on one end, other end was simply splitting off..
So, this is scrap…bring a third board to the shop..
Wavy edges,,a few knots….that I can cut around….goal today…was to get enough blanks cut up, to make four more panels…means cross cutting a bunch of 11” long blanks..
12 boards in all…with bad edges, and quite a few tapers…..set up the rip fence at 5-1/2” or so from the saw blade…run all 12 boards through…while running the eye-balled straightest edge along the fence…and then mark the new edge I just sawn….then reset the fence a bit..to 3-5/8” and run the sawn edge along the fence and stack the good blanks aside…the 1×2s? May make a cutting board from them..someday…
Next…sort through to get the best grain matches, including the 1×2 filler..
had a few gaps..we have ways..
Clamp the part into the jig..and joint the edges as needed..almost time for the glue….first, I need clamps…as the available clamps are on the first 2 panels…removed the clamps, and set the panels on the bench…
Glue, clamps and cauls time…panel wanted to bow a bit….flattened that out….set this aside, and do one more panel…as that is all the clamps I have in this size..
The first 2 panels?
Will clean them up and square them up, tomorrow…while I am trying to glue up the last 2 panels…
As I need my saw back….once the panels are all cleaned up and squared, I can start to raise the panels….need to make a jig to hold the panel, while I plane a bevel all the way around….with a Stanley #4….ala Paul Sellers..
Stay tuned….
2 comments so far
View Dave Polaschek's profile
Dave Polaschek
10291 posts in 2043 days
#1 posted 11-07-2020 04:12 AM
Big pieces into small, and back into big, but arranged differently. Some days it just feels like rearranging furniture.
I’ve got a panel I want to make of a bowtie tesselation. With holes in the middle of the bowties. And made up of over a gross of bowties. I cut them out of scraps and throw them into a bucket when I need to think about something else…
-- Dave - Santa Fe
View controlfreak's profile
controlfreak
3752 posts in 1062 days
#2 posted 11-07-2020 02:43 PM
Well there is my answer on getting the bevel on the panels. Looking good!
