Block plane box #4: Box #2, lid completed
Blog entry by bandit571 posted 05-21-2020 08:06 PM 195 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 3: Box #2 Part 4 of Block plane box series no next part
Not working as fast or as long as I used to…but…had the parts all cross cut to size…time to start making box joints
Used this 1/4” chisel, to lay out the fingers….then a bandsaw to make a lot of cuts…seems to help when I chop the waste out….
Got these two corners done…then the Boss needed to go to the store…came back and tried the last two corners…
When I laid out the fingers for the #3 corner….somehow the part got flipped the wrong direction…grrrrrr
Completely remade that end, from a new piece of pine…was able to fit all four corners together enough that a glue up could be attempted…
That caul is there, because a clamp wanted to slide a bit too far in..and bow in the side….clamp was there to clamp in the topper…once it had been cut, sanded and planed to a slip fit….line a glue and slide it in place..
About like herding cats..get 2 or 3 corners in place, and the others would pop out….finally all 4 rested where they were supposed to go…barely…
This morning, those clamps came off..test fit showed things were a tad out of whack….sanders to correct some of the spots..but, the inside of the lid was a bit too tight…we have ways…
A SHARP, wide chisel…hand and a chin to power it down….soon removed the “fat spots”...
Chisel is an 1-1/2” wide Stanley Handyman. Test the fit one more time..
Lid was about 1/2” too tall, so the tablesaw was used to trim things down a bit….
View is of the bottom of the two boxes….almost a piston fit…almost a shame to close the “vent”
Then coat of the Witch’s Brew…
Need to find a Shelton label to draw on…and then add it to the end of the lid….after the Brew is dried.
Plane is a Shelton No.18 All Steel low angle (15 degrees) block plane…..
Next plane?
Seems a hair wider….and has a bit more in the trunk…
Wondering how dovetails might work with these small boxes…..only one way to find out…
Stay tuned…
3 comments so far
View lightcs1776's profile
lightcs1776
4254 posts in 2391 days
#1 posted 05-21-2020 11:29 PM
Looking good. Love seeing these updates.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View bandit571's profile
bandit571
25595 posts in 3420 days
#2 posted 05-23-2020 10:45 PM
And a label..
That will do….next block plane boxes will be a little …different….
Stay tuned…
bandit571
#3 posted 05-24-2020 06:32 PM
The next little boxes will be a bit different…both in the corner joints, and the lid used…Whether to start a new blog, or keep this one going? Not sure just yet…
