Shop Cabinet build #12: Plugs done, latches installed, stain applied
Blog entry by bandit571 posted 04-04-2020 01:09 AM 778 reads 0 times favorited 4 comments Add to Favorites Watch
« Part 11: We have hinges! Part 12 of Shop Cabinet build series no next part
Update on that plug cutter, needed sharpened…and a skinny board for the vise on the drill press. was having trouble cutting the plugs..
Once they were made, a small screwdriver could pop them out, dab of glue on the narrow end, and tap into place..
let the glue set a bit. Chisel and a tap with the hammer to trim the plugs down…block plane to smooth things out.
Sharpened the cutter, today..
And made the last 11 plugs. made a road trip to Lowes, and picked up the latches..
used a tool by Irwin, to start the screw holes..
hard part was setting the latches so they closed the doors up tight..
Then installed the last of the plugs, trimmed them flush, and sanded them smooth..
IF you watch how the grain runs, plugs will almost disappear…almost…Then gave the door#2 a brushed on coat of Witch’s Brew..
Added a strip to the bottom edge of #2
And a couple more keepers for the braces..
getting a bit crowded? Chisel rack also got a finish…to protect the steel from the Oak in the rack..
So…I think this is about ready to “open for business”?
just be sure to close the doors, when done..
Might be ready to post as a “Project”?
Insides are still a work in progress, trying to find the best way to stash things…without a crowd…
Piling up in the corners…
Stay tuned..
4 comments so far
View BurlyBob's profile
BurlyBob
7411 posts in 2994 days
#1 posted 04-04-2020 01:20 AM
Bandit you never cease to amaze me how fast you build and finish a project. It’s another winner!
View robscastle's profile (online now)
robscastle
7069 posts in 2933 days
#2 posted 04-04-2020 06:56 AM
Bandit your holding out on the plug cutter sharpening
skills.
I see a triangular file and a subject plug cutter but no competency skills that you used to get it serviceable again.
BTW I checked my Leonard Lee The complete guide to Sharpening but he used a triangular stone of which I do not have.
-- Regards Rob
View bandit571's profile
bandit571
25538 posts in 3412 days
#3 posted 04-04-2020 07:55 AM
used a needle file. just followed the angles already there.
It had a lot of carbon build up, from burning it’s way through Ash and Oak…
I had it clamp points upward in the vise. And just followed the angles.
robscastle
#4 posted 04-04-2020 09:48 AM
I will have to give it a try …Thanks
-- Regards Rob
