Can of stain has been stirred up, and used. Couple trouble spots fixed. Hinges were re-located….yeah, about time to show off a bit…I added some “feet” to the bottom of the box…
Nothing fancy, though…Hinges were moved a bit..
With the result that they can prop the lid open…next, was the drawer’s problems…
Had to plane a bit, to get a better fit, without it getting stuck…There used to be a square hole, beside the right top corner of the opening…the “extra” groove was filled…by attaching the “guide strip” to the drawer..
Can you see it? That is the idea….
A view of the back….nothing special here..
Kind of like the way the grain almost lines up.
Stain has been wiped down, letting it dry overnight..and see about a top coat or two, tomorrow?
Then I’ll post the “finished” box over in Projects…as the woodworking part is about done…
Thanks for following along!
3 comments so far
Steve
home | projects | blog
112 posts in 4436 days
#1 posted 01-23-2020 02:30 PM
That looks really sharp. Ordinarily, I’m not a big red oak fan (seen too much bedroom furniture and entertainment centers made out of it in the last 30 years!) However, that grain has a nice classic look to it. Well done!
-- https://www.commercialforestproducts.com/good-swamp-ash/
Andre
5253 posts in 3268 days
#2 posted 01-23-2020 08:00 PM
Just amazing how well thing work when we cut the Tails First:)
bandit571
31914 posts in 4145 days
#3 posted 01-23-2020 08:33 PM
Hmmm…pins first..
I like pins first, I get a better, tighter fit that way…I did tails first on this Sellers box because that was the way Paul Sellers did his version….Next project? Going back to pins first..
