DVD Cabinet of Ash #2: Flatten the curves
Blog entry by bandit571 posted 10-17-2019 01:20 PM 267 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 1: Start up Part 2 of DVD Cabinet of Ash series Part 3: Dovetails and other joints »
and straighten the edges…For some reason, I decided to joint the edges first…
Hmmm, we have ways.
I have 2 Stanley No. 6 small jointers in the shop…and gave both a work out….because one has a smooth sole, and the other is a “c” model…
Any difference? Not really…Ok, got 4 edges jointed, and parallel to each other, with the sides matching in width..next up…
To try and flatten a bit of cupping going on….
I worked the high spots down with the No.6….then followed up with a No. 4
And check for flat as I went..
Then rinse, and repeat, until all 4 faces are flat….have 2 boards that are now S4S…and a pile on the floor..
Set them aside, for now….and round up the “Usual Suspects”..
As the blank for the case’s bottom needs some lay out done..
IF I lay things out just right, that bad corner will be around in back of the case, and covered by the plywood back..
That will sit in a rebate…
Stay tuned….
0 comments so far
