A computer desk #12: Lid installed, PIP
Blog entry by bandit571 posted 01-21-2019 04:04 PM 818 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 11: Lid work Part 12 of A computer desk series Part 13: Plugs and drawers »
2 hour shop time last night, 4pm to 6pm….parts for the lid were taken out of the clamps, sanded clean, and squared up. Bread board ends needed trim a bit. Found a strip of scrap that I could use to set the “meeting angles” of the lid
Short section is for the top shelf. Once the angles looked decent, I could use these to set the bevel on the tablesaw
The long section needed a bit of clean up, bandsaw did a wavy cut….once that was where it matched the top shelf’s already cut angle..
And double checked I was cutting the bevel on the correct edge…I could set the saw, and make the rip cut…Then worked on the hinges….after I had drilled a few mounting holes, and screwed the top shelf in place..
Usual toys when doing very small screws…candle wax on the brass threads helped a lot…
Screws were driven by hand. Finally got both hinges installed..
C clamps are for gluing on a book rest strip..
Let this sit until this morning, then the clamps came off, and the lid was closed…
Hope the Dark Walnut stain like I used on the Coffee Table project will make the grain “pop” a bit
PIP?
Front view….debating on a “topper”, though..
Too small? Not big enough? too plain? Shop is a bit too cold, today…need to make a bunch of Ash plugs, to cover all the screw heads….and maybe start on a drawer, or two. Had to bring the glue upstairs…
Stay tuned…
3 comments so far
View Andre's profile
Andre
4827 posts in 3089 days
#1 posted 01-22-2019 05:49 AM
Had to turn heat down in the Shop up here, temp almost at freezing outside? That Desk looks so good, wish I had an excuse to build one!
View lew's profile
lew
13442 posts in 5039 days
#2 posted 01-22-2019 07:18 PM
Sure is lookin’ good!
View leadfoot67's profile
leadfoot67
1 post in 1041 days
#3 posted 01-24-2019 10:03 PM
That desk sure is looking good so far! I wish had the time to add another project. I like the overall style that you chose, great idea! Keep up the great work!
