End Table, out of Ash #1: Starting up
Blog entry by bandit571 posted 11-22-2018 06:22 AM 619 reads 0 times favorited 4 comments Add to Favorites Watch
no previous part Part 1 of End Table, out of Ash series Part 2: Legs and other follies »
Well, the Boss has decreed, she wants a new end table,,,,went to a friend’s place, and brought back a few boards
12’ of 4/4×6 ( cut in half, to fit in my van)
10’ of 7/4×4( ditto)
Plan calls for a table about 23” tall…16” wide, by 30” long…Hauled the 1xs to the shop…cut 4 blanks 30” long
3 out of the 4 weren’t too bad…#4?
All of these were from the same board? Ok…..checked the others with a straightedge..
Well, I can bandsaw the worst off. then straightline rip all the edges…then use a plane or two, to joint them for a glue up…
When I laid all three planks out, I was looking at the grain match…
Once I liked it, I drew a big “V” across all three, to keep thing lined up….WR #62 and the Stanley No. 7c to joint the edges….checked for gaps, as I went..
Was finally able to moosh some glue around..
Only thing holding these three is the glue. Called a rubbed joint….spread a bead out, sit the next board into the bead, rub the board back and forth (maybe 1-2” travel) until I feel the glue stick…repeat for the other…
Used clamps, mainly because I also needed cauls on each end..
I start in the center, then do each end…cauls and all. Let this sit a day or two…
OK, today was a short hour in the shop. Removed the clamps, but not the cauls, and set the panel aside..
It can sit right there, until needed. Hauled one of the 2×4s to the shop….needed 4 blanks, roughly 22” long.
Had to hunt & peck a bit, to avoid the worst of the knots…and splits. Then set up the rip fence, to the thickness of the boards ( 1-13/16”) and ran the boards through…...had to flip the board over…little saw does not reach high enough…Grrrrr. Wound up with the 4 squares..
I also ripped that wavy 1×6 down…
Fence was still set up for the leg blanks. I figure by the time I crosscut these 1×2s and plane them flat, they will be aprons for a bottom shelf, that the Boss also wants. Clamped those into the vise..
Hmmm…we have ways..
Let this sit a few days. I also tried a tapered leg…
Started 5” from the top….at the foot the taper leaves 1”. Marked out, rough cut on the bandsaw, leaving most of the line….Will come back later, and a hand plane to smooth the taper out flat. taper is on the two inside faces.
Went over the blank a couple times….the waste will cut the “bad” stuff off…had to make sure I got the better looking stuff in the leg, on both faces..
Two days of shop time…maybe 4 hours total…
After the Turkey Day festivities are done, I can get back to work….stay tuned.
4 comments so far
bandit571
24334 posts in 3283 days
#1 posted 11-23-2018 02:06 AM
Shop is closed for Thanksgiving. Have a great time, thanks for looking in!
View socrbent's profile
socrbent
906 posts in 2869 days
#2 posted 11-23-2018 02:37 AM
Good luck with your new project. I am thankful for LJ’s like you and your taking time to make these posts.
-- socrbent Ohio
Rick Dennington
6789 posts in 3794 days
#3 posted 11-23-2018 03:40 PM
bandit,
The end table is beginning to take shape…I always enjoy stating a new project….I like building furniture like end tables, coffee tables, sofa tables, etc…..Get lots of calls for them….I’ll be following along…!!
-- " There's a better way.....find it"...... Thomas Edison.
View lew's profile
lew
12930 posts in 4355 days
#4 posted 11-24-2018 12:49 AM
Great start on this one!
