That OddLots Ad #3: 1st panel glued up
Blog entry by bandit571 posted 09-08-2018 12:05 AM 552 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 2: Starting up Part 3 of That OddLots Ad series Part 4: Panel #2 is in the clamps.... »
Just couldn’t stay out of the shop, that day ( paid for it the next..OW!) so after supper, I went back to the shop..
Instead of that huge #8…went with the lighter #7c….got an edge on one 1×6 jointed, test with the filler strip for gaps. Mark both as to where they will meet…worked the second 1×6 straight…only worked on one edge, for now.
Got to where all three would sit still, without clamps or glue…more markings. One 1×6 stayed put, in the vise, a bead of glue was run along the freshly planed edge, the filler strip added ( by sliding it around, until it “stuck”), then a second bead was applied to the filler strip’s edge, and the other 1×6 was slid around…The mess even just sat there, no clamps were needed to keep them there..but…
I started with a clamp in the middle…then a clamp at each end…
After going to the trouble of making sure one end was straight, a caul was clamped in place to keep it flat as well..this will be the top of the panel…trimming is being kept to as little as I can here….
Far end, where a foot profile will get cut out, still needed a caul, to pull things flat..
Swept the floor, and called it a day…the next day was a shopping day….pine 1×2s for webframes were picked up, and a pair of 1×12x 4’ pine planks. They will be the center (unseen) dividers…
Shopping day…I stayed out of the shop…was doing errands all day.
Stay tuned….
2 comments so far
View lew's profile
lew
12938 posts in 4363 days
#1 posted 09-08-2018 12:36 AM
Nice!
Rick Dennington
6789 posts in 3802 days
#2 posted 09-08-2018 02:34 PM
Moving right along…..Keep up the good work….I’m still watching…..!!
-- " There's a better way.....find it"...... Thomas Edison.
