A Stepback Cupboard build #11: Face frame, and a bit of assemby work..
Blog entry by bandit571 posted 01-25-2018 07:09 PM 597 reads 1 time favorited 1 comment Add to Favorites Watch
« Part 10: Shelves, and a top shelf Part 11 of A Stepback Cupboard build series Part 12: Bookcase needs a door »
Maybe even a PIP?
Got the parts for the face face milled..
Jointed the edges. Milled some tenons..
That I thought were correct…..was a bit too much tenon….
Chopped a few mortises…
Until I could do a glue up..
Later, came back and tried a dry fit to the front of the case…case was wider than the frame….added a thin strip along the outside edges. Drilled a counter bored holes. Marked out, and drilled counter bored holes to attach the top.
marked radius on the front corners of the top. Ran a cove bit around both ends and across the front of the top….on the underside.
Attached the top with a few screws…will need to plug the counter-bores with more Walnut plugs. Attached the face frame, using a few screws…
Added a pair of cleats..
To attach the bookcase to the lower case…..
Two screws into the sides of the bookcase. Step back a ways, inorder to get the entire project into the picture..
PIP
Yep, going to be a tall one. Need to start building the raised panel door, next.
Stay tuned….
1 comment so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 1286 days
#1 posted 01-26-2018 12:33 AM
Looking good as always, Bandit. Keep up the good work.
