Shop storage projects #10: That dresser build, side 2 rails are done...
Blog entry by bandit571 posted 01-17-2017 01:19 AM 851 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 9: The dresser build, side #2 is started... Part 10 of Shop storage projects series Part 11: Dresser build: side #2 is done.. »
Ok, spent a bit over 2 hours in the shop today. Since the rails were all ready to go, might as well get them done.
Still had the stanley 45 set up, so a lot of this type of work was done..
But, being a Monday, has having a problem with this set up. Not with the plane, but how I was holding the part to be planed….too many screw holes. Decided to address that problem..
Piece of 1×6 scrap, held flush with the top of the bench. Two screws to attach. Now, it doesn’t matter where the parts are screwed to the scrap. Later, I can just rip the bad strip off.
Anyway, After each and every rail was finish being molded, I tried to cut the tenons. I needed the space between the two tenons to be as close to the exact length as the pattern called for. pattern being the top rail in side #1.
I had already added a scrap to the deck of the mitre box, as there had been issues with not cutting all the way through stuff. First off, a single screw now holds the scrap to the deck, to prevent it from sliding around.
Next, a pencil line was drawn on the scrap, to show where the end of the tenon would be. All i had to do was barely touch that line with each end of the part, do a bit of saw work..
By crosscutting down to the bottom of the molded edge. Which left this much beyond the saw…
I think you might just make out the pencil line. Now, the other day when i was sawing away the waste from the tenons, a backsaw was used. Was not the quickest way, nor the straightest way. Hmm..decided to use a jig on the bandsaw. Same jig I used for resaw work. I set the jig so that the waste was between the blade and the jig..
I could then sit the part up on an edge, and saw the waste off. A quick clean up with a chisel. and od to the next part. Between the jigs, I was able to make all six rails come out almost exactly alike..
Normal Mondays in the shop usually end up with something thrown against a wall, or something broken….none of that happened this time. I do know that the Stanley 45 will make a mess on the floor…
I even checked this stack with a square, all are within a 1/16” of each other. Not too bad for a Monday?
And this would have been the third time I swept the place today. No wonder Igor quit.
Maybe tomorrow, I can start on the corner posts? So, maybe by this weekend, I can have the casework done?
Stay tuned…
2 comments so far
View Miataguy's profile
Miataguy
157 posts in 1914 days
#1 posted 01-17-2017 12:50 PM
Looking forward to seeing this Saturday if I can get up there…we should still be on for the get together, right?
Chris
View bandit571's profile
bandit571
24663 posts in 3322 days
#2 posted 01-17-2017 02:05 PM
Yep.
