1880s Counter #3: One (Re-)Turn Deserves Another
Blog entry by Smitty_Cabinetshop posted 01-15-2020 01:38 AM 612 reads 0 times favorited 12 comments Add to Favorites Watch
« Part 2: Okay, What Exactly Do I Have? Part 3 of 1880s Counter series Part 4: Figuring things out »
If you’ve paid attention thus far, you know the counter was cut off on one end, and that a single example of a ‘return’ is all I have. Aside from being incomplete (bottom rotted away), it will serve as a good pattern for a recreation piece for the other end of the counter.
I propped it in the face vice of the bench to have a look.
I need to rehab this original piece to replace rot, but first it must be duplicated! Face boards are 7/8” stock. Stiles (?) are a full 1” thick. Applied moulding are three pieces per side on a recessed rectangle. I have old pine in all those dimensions, and if I don’t, I’ll make it.
Through the magic of the internet (and lacking pics, because I didn’t know I was going to blog it at the time), here’s dressing the inset panel…
and then the completed face panel as I begin work on the inset mouldings! Wow, that’s amazing, right? But then creating a frame in nothing big in and of itself, so let’s get to the dressing. I have cove for the inset, but it wasn’t 7/8 on one side. A bit of shimming took care of that.
Cut the cove on the Goodell-Pratt (as I will all the moulding from this point)...
and used the shoot plane to get it just right (as I did with all twelve pieces of this inset assy).
Then had to come up with 5/8” wide half-round moulding. I thought about using the No. 55, but there’d be nothing to rest the plane on (intended to do this to a long edge of 5/8” stock).
So it became a job for the H&R set. Doesn’t need to be perfect, just needs to be consistent.
Then needed 3/8” half-round, 1/2” deep. Used a beading plane to create the round…
then ripped it free with the table saw, creating the piece I needed.
Presto, the completed ‘mirror image’ copy! First, the original:
Then the reproduction:
I’ll spare the gory detail, but I then turned to the original to replace the rotted bottom face board and ‘stretch’ the stiles to a much more useable length.
And I said this installment would talk about board stretching. Here’s a board that needs help.
I have no clue as to how long it needs to be, but what’s there ain’t enough. I located some appropriate (7/8” thick) pine stock and cut the rot away until I got to solid material. I also wanted as much glue surface as possible.
Out of clamps.
I then set the table saw fence, ripped the addition it to proper width, then made a copy of said piece.
Next time, more clues emerge on how this thing needs to be reconstructed. And a revisit of the top. Until then, thanks for looking!
12 comments so far
View chrisstef's profile
chrisstef
18027 posts in 3613 days
#1 posted 01-15-2020 02:04 AM
Gutsy. I like it.
Im out of scotch.
View theoldfart's profile
theoldfart
11055 posts in 3058 days
#2 posted 01-15-2020 02:06 AM
Great progress Smitty.
Is that Dad I see in the background?
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Smitty_Cabinetshop
16339 posts in 3225 days
#3 posted 01-15-2020 02:07 AM
Get more, I’m not halfway yet! :-) And, yes!
chrisstef
#4 posted 01-15-2020 02:21 AM
Twisted my arm.
View Don W's profile
Don W
19428 posts in 3174 days
#5 posted 01-15-2020 11:26 AM
i’m tired just watching.
View JayT's profile
JayT
6358 posts in 2818 days
#6 posted 01-15-2020 01:43 PM
Impeccable work, as always, Smitty. I love following along on your rebuilds.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View AnthonyReed's profile
AnthonyReed
10120 posts in 3047 days
#7 posted 01-15-2020 06:30 PM
Such good stuff.
Agreed JayT, I love this show!
Thank you Smitty.
-- ~Tony
Smitty_Cabinetshop
#8 posted 01-15-2020 06:41 PM
Hi Tony! And All! This is an interesting piece, the biggest one i’ve done by far.
theoldfart
#9 posted 01-15-2020 08:09 PM
Where are you putting the spittoon and brass rail?
View HokieKen's profile
HokieKen
12002 posts in 1745 days
#10 posted 01-15-2020 08:10 PM
Nice work Smitty. Looking forward to the rest :-)
-- Kenny, SW VA, Go Hokies!!!
View 489tad's profile
489tad
3731 posts in 3618 days
#11 posted 01-15-2020 10:19 PM
Making a bar! Nice repair and a Tony sighting. It’s a good day.
-- Dan, Naperville IL, I.G.N.
View James E McIntyre's profile
James E McIntyre
569 posts in 1899 days
#12 posted 01-16-2020 10:48 PM
So far so great. You have a very impressive shop and tool collection.
-- James E McIntyre
