Sawmill Short Log Clamp #1: Adjustable clamping system for short logs on a Woodmiser
Blog entry by Jim Jakosh posted 05-16-2021 01:56 PM 864 reads 1 time favorited 8 comments Add to Favorites Watch
no previous part Part 1 of Sawmill Short Log Clamp series no next part
I was given an apple tree to cut down and the plan was to make boards out of it rather than all logs for turning. I had never had any apple boards before so i consulted with LJ KPOSTY about doing it on his sawmill. The clamping setup would not hold a log that short (33”) so I made him a clamping system similar to the one John Goodwin uses at the Dead Tree Salvage mill in Casa Grande, Arizona.
I had to modify the location of the front rail because the bar support on the right side is out farther than the left side..but no worry, we just drilled a new mounting hole in the front to back perforated tube and bolted it on.
It is adjustable front to back and up and down by the use of the red pins in the perforated tubes. the front to back perforated tube can be moved side to side on the Unistrut channel because there are floating nuts inside the channel that can be used in any of the slots .
The clamp with the teeth in it is removable and just the point of the 5/8” screw can be used to bury into the log. The clamp is made such that the hole in the back has the center just above the top of the teeth so there is a natural down force on the piece being held. he can now cut a piece as short at 26”.
More back stops are in the works as is a V clamp for hold rounds standing vertically.
Cheers, Jim
8 comments so far
View lew's profile
lew
13366 posts in 4875 days
#1 posted 05-16-2021 02:04 PM
Cool idea, Jim! Looks like it worked perfectly.
View doubleDD's profile
doubleDD
10429 posts in 3162 days
#2 posted 05-16-2021 02:44 PM
Nifty set up Jim and well worth the effort for that apple wood. I always try to split up the way cutting, some for boards and some for turning when possible. I have a ornamental tree sliced up waiting to dry.
View recycle1943's profile
recycle1943
5486 posts in 2741 days
#3 posted 05-16-2021 02:48 PM
way to go Jim, that’ll open up plenty of opportunities
-- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them
View corelz125's profile
corelz125
3039 posts in 2095 days
#4 posted 05-16-2021 04:18 PM
Uni strut that stuff is great. Doesnt surprise me you came up with an idea to make it work. Nice work Jim
View Cliff 's profile
Cliff
1927 posts in 2843 days
#5 posted 05-17-2021 11:12 AM
Good work Jim…Any milling of wood is fascinating. Just so good to see workable lengths of timber being formed with very Clever Engineering.
Well Done…Regards…...Cliff
-- Cliff Australia : Snoring is good. It blows away all the Sawdust.
View Jim Jakosh's profile
Jim Jakosh
26300 posts in 4225 days
#6 posted 05-17-2021 01:21 PM
Thanks you all for the good comments. It sure enhances the mill to make it more versatile.
Hi Dave. Kan and I cut the tree down….took 5 logs to the mill and the neighbor delivered 3 pieces to my barn for turning. All the rest of the tree was picked up by a guy for his smoker.
Hi Danny…........Unistrut was the way to go. It is galvanized but I sprayed everything with stainless steel paint also because the mill sits outside.
Cheers, Jim
View mafe's profile
mafe
13202 posts in 4208 days
#7 posted 05-27-2021 11:28 AM
You are the man Jim, Mr. Get it done.
Bravo and cheers.
Best thoughts,
Mads
-- MAD F, the fanatical rhykenologist and vintage architect.
Jim Jakosh
#8 posted 05-27-2021 12:13 PM
Thanks, Mads. There are now two more log clamps for holding them vertically in the mill to cut rounds. One is for the mill in Arizona.
Cheers, Jim
