Whiskey Tango F.. Box #2: BJTS: Box Joints with a Track Saw
Blog entry by PurpLev posted 01-03-2021 07:42 AM 503 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 1: A light in the Chaos: rough cuts Part 2 of Whiskey Tango F.. Box series Part 3: Glugluglug... »
If you’ve seen the last photo in the previous post, you probably saw the hint for the box joints planning. I like box joints in general, and find that they will have a great visual benefit in this project (Beyond the obvious strength and alignment), Since I planned to have more than a few of those than would make sense to hand cut and chisel cut them, I figured I’ll try to setup some fixture for harnessing the track saw for this. Sort of reversed tale saw box joint sled idea (minus the sled). I started with vertical mounting a tall panel that would allow my parts to slide side to side, and added a T panel on top for the saw to rest on (added some support from the front to handle the saw weight and tilting forces when applied):
I left a little overhang of the vertical panel so that I can cut it with the saw and have a kerf guide mark for my cut boards. Also made sure they are dead square:
Using an orphan bolt, I drilled a hole for it to thread into as an anchor to the saw:
Then mount the saw with it and add some rest stop on the front to keep the saw straight:
Make a kerf cut for guidance:
Clamp a board and make a test cut:
Cut too short (that’s a good thing). The nice thing about track saws is the fine adjustments and stops for depth of cut:
I rarely look at the numbers, but adapt to depth of parts, hold saw at cut length, and move the stop to that position. After adjustment looks much better:
Move to other end of slot and make a 2nd cut before ‘rinse-and-repeat’ in between to clean it up:
This jig is a make-up and tear down so nothing fancy. I screwed some support to hold the piece at proper height, so all I need to do is just slide it across as I make the cuts:
All in all, not too shabby, I’m pretty happy about the results:
After completing this, I just took the whole thing apart. Maybe in the future I can come up with a more permanent and adjustable solution, but for now, this did the trick:
While working on this, I did experience the saw starting to drift from it’s straight guide (I only mounted it with 1 bolt). So ended up clamping the other end of it:
Next was the front and back. Used 1/2” material, rough cut the rabbets with the track saw, and cleaned it up with a plane:
Dry fit before calling it a day, did have to adjust and find tune some of the cuts, but we are off to a good day’s work:
Next.. glue up.
5 comments so far
16292 posts in 5296 days
#1 posted 01-03-2021 02:31 PM
Very creative setup, Sharon. I’m glad to see you getting a little shop time in. We’re going through back-to-back total gut-job bathroom renovations, so my shop has become little more than a storage place for materials since before Thanksgiving.
View robscastle's profile
robscastle
7874 posts in 3282 days
#2 posted 01-03-2021 06:26 PM
A quick fly over with the M134 should fix things
-- Regards Rob
View mafe's profile
mafe
13185 posts in 4167 days
#3 posted 01-03-2021 11:37 PM
Less is plenty, love your thinking.
Looks good,
Mads
-- MAD F, the fanatical rhykenologist and vintage architect.
View PurpLev's profile
PurpLev
8652 posts in 4726 days
#4 posted 01-04-2021 04:51 AM
Charlie sounds like we share the same woodsho… I mean storage space ;)
Mads – yes, sometimes less is more, and sometimes even less is too much :)
View mafe's profile
mafe
#5 posted 01-04-2021 10:17 AM
Laughs, true. ;-)
