Drill Press upgrade I made. When you get older you need additional help.
I installed a light using a downlight fitting with a LED bulb in a can which is the perfect fit. The only cost was the LED bulb at about $2 US (R30 in South Africa) as I had all the other stuff.
I made an adjustable arm from some flat bar that I also had lying around.
And while I was busy with lighting I also installed a 20wat LED tube light in my shop. Makes a HUGE difference. I should have done that a LONG TIME ago!
-- Sometimes life gets in the way of one's woodworking :)
4 comments so far
Steve
home | projects | blog
104 posts in 3989 days
#1 posted 02-07-2020 02:34 PM
Very creative! I like it.
-- https://www.commercialforestproducts.com/good-swamp-ash/
Rick Dennington
7140 posts in 4209 days
#2 posted 02-07-2020 04:41 PM
Very nice…..Good idea to use a can…..money saver….!!
-- " There's a better way.....find it"...... Thomas Edison.
crowie
4344 posts in 2966 days
#3 posted 02-23-2020 10:24 AM
Clever and innovative!!
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
splintergroup
4714 posts in 2237 days
#4 posted 02-23-2020 03:27 PM
I love the “build it yourself” attitude! You can get exactly what you need without spending a fortune or making compromises.
My only suggestion is to add some venting holes at the top, LEDs (the power supplies in the bulb base) don’t last long when subject to elevated temperatures. That said, a work light usually isn’t lit up for hours on end so you probably will never notice 8^)
Creative and solid!
