Hey everybody I need some help I built a juice groove jig, but with a disability I have {3 fingers paralyzed) I can not keep the router tight like I want to I was hoping to find a small router to take 1/2” shank bits, but so far no go so my question is what about wobble on 1/4 shank core box bits up to 5/8” Any ideas would be helpful I can make a plate for palm router I think so I can use the Jig. Thanks for any help
-- woodnutbob
6 comments so far
Rich1955
home | projects | blog
402 posts in 847 days
#1 posted 09-01-2020 12:45 PM
I have severe arthritis in my left hand and sometimes I have a hard time holding my router steady. I purchased a Bosch Colt 1.25 hp palm router and thought it would help. with the small base I was having the same problem. I found a larger base online that will take standard PC. guide bushings and what a difference. I can hold it steady as long as I go slowly. I never used a 5/8” core box bit but I have used 1/2” and it works fine. Hope this helps, and it sucks getting old.
-- Rich
bbain32
43 posts in 2632 days
#2 posted 09-01-2020 11:17 PM
Even without a hand troubles I have struggled to keep the router pressed against the fences of a juice groove jig. I have thought about making an inner fence that sticks down with double sided tape to keep the router base trapped between the two and keep it from wandering.
robscastle
8543 posts in 3661 days
#3 posted 09-02-2020 08:00 PM
Maybe ask another woodie to do it for you.
with a offer of return of service for their help
-- Regards Rob
118322 posts in 5034 days
#4 posted 09-02-2020 09:15 PM
Not sure how much experience you have ,but many of my students who have this problem are not routing from left to right? I also recommend for better control using a “D” handle router. Lastly I also find it’s easier to use a guide to help stay inline ,see links below. As far as vibration in router bits,1/2” shanked Router bits have less vibration.
https://www.amazon.com/PORTER-CABLE-691-Enrutador-clavijas-pulgadas/dp/B0000222VJ/ref=sr_1_1?dchild=1&gclid=Cj0KCQjwhb36BRCfARIsAKcXh6EvVhAUjV0yuIscivGcpEbTV5XT9pvzqlxRoOgjv_ao9YCT7AKieg8aAvqOEALw_wcB&hvadid=177783082319&hvdev=c&hvlocphy=9033082&hvnetw=g&hvqmt=e&hvrand=496320618700716046&hvtargid=kwd-900075379&hydadcr=1645_9901544&keywords=porter+cable+d+handle+router&qid=1599080792&sr=8-1&tag=googhydr-20
https://www.amazon.com/PORTER-CABLE-42690-Guide-Models-Routers/dp/B0000222V9/ref=pd_bxgy_3/136-8547197-4733212?_encoding=UTF8&pd_rd_i=B0000222V9&pd_rd_r=ef1d9e5f-4d08-4763-aaa9-ecee8b493953&pd_rd_w=boxDt&pd_rd_wg=nkVga&pf_rd_p=ce6c479b-ef53-49a6-845b-bbbf35c28dd3&pf_rd_r=78F2VYBBAZ6BSKRV7954&psc=1&refRID=78F2VYBBAZ6BSKRV7954
robscastle
#5 posted 09-03-2020 11:58 PM
Hey I almost forgot its possibly a good reason to buy a CNC router tee hee.
-- Regards Rob
robscastle
#6 posted 09-07-2020 12:01 AM
I am moving to Budapest
-- Regards Rob
