Gluing rigid foam insulation to self
Blog entry by Bob Casey posted 04-29-2018 09:32 AM 1154 reads 0 times favorited 7 comments Add to Favorites Watch
I want to glue up Pink rigid foam insulation. The thickest I can find is 2” and I want to make a core for large Shaker Oval boxes and I need to glue up a 6” thick core. I could glue up wood but that would be too heavy to use. what type of adhesive will glue up rigid foam? someone told me to put 1/8” plywood between layers of the rigid foam but again what to use as an adhesive. Thank you for your help
-- woodnutbob
7 comments so far
View cutmantom's profile
cutmantom
408 posts in 4372 days
#1 posted 04-29-2018 11:36 AM
There should be a construction adhesive for that, check the label for recommended uses
View SPalm's profile
SPalm
5338 posts in 5219 days
#2 posted 04-29-2018 11:45 AM
For shaker box forms and such I would use 3M spray adhesive. It is not going to be outside and exposed to all the elements.
Also it routes well. Rigid foam and soft foam cut well with an electric carving knife just for info.
Steve
-- -- I'm no rocket surgeon
View Gene Howe's profile
Gene Howe
12475 posts in 4765 days
#3 posted 04-29-2018 12:02 PM
Steve
- SPalm
Ditto. I use it on French fit gun presentation boxes and it works well to adhere foam to wood or, to it’s self.
For a stronger bond, Weldwood Contact Adhesive also does the job. But, the smell lingers.
View SirFatty's profile
SirFatty
547 posts in 3549 days
#4 posted 04-29-2018 12:07 PM
I’ve seen the expandable foam (Great Stuff, et al) used for this purpose.
-- Visit my blog at dave.spalla.com
View johnstoneb's profile
johnstoneb
3190 posts in 3509 days
#5 posted 04-29-2018 12:28 PM
I would go the 3M spray adhesive. Be careful on rigid foam with contact adhesive I have seen the adhesive react with the foam and the results were not pretty.
-- Bruce, Boise, ID
View Woodknack's profile
Woodknack
13585 posts in 3717 days
#6 posted 04-29-2018 06:38 PM
View Bob Casey's profile
Bob Casey
85 posts in 2818 days
#7 posted 04-29-2018 07:42 PM
I want to thank everybody for telling me what adhesives to use everybody was very helpful I will pick up 3M spray adhesive and Loctite tomorrow. I will try them both and the suggestion of an electric carving knife time to hit the garage sales or flea market for that. but a good idea
-- woodnutbob
