Cutting thin plywood
Forum topic by MrRon posted 01-29-2019 10:51 PM 1057 views 0 times favorited 45 replies Add to Favorites Watch
View MrRon's profile
MrRon
5351 posts in 3508 days
01-29-2019 10:51 PM
Topic tags/keywords: question
As a model train maker, I use a lot of aircraft plywood for the bodies. The plywood I use is 3 ply, 1/16” thick. Cutting it to size is no problem as I can cut it with a saw. Cutting window and door openings is a problem. I layout the openings accurately with a thin lead and cut the outline. Openings are around 1”x 1” up to around 3”x 5”. I have used all kinds of sharp knives and razor blades, but it is tough going. I wonder if there is a tool that would cut clean openings in 1/16” plywood. I’ve thought about using a jewelers saw, but that may cause tear out. I’ve even tried drilling overlapping holes and cleaning up the opening with sanding sticks, chisels and razor blades. I just discovered a new product called “Wonder Cutter” that cuts using ultrasonic technology; cost $400; not an option. Maybe someone has an ingenious way of cutting; please let me know.
45 replies so far
View RDan's profile
RDan
96 posts in 2588 days
#1 posted 01-29-2019 11:04 PM
Have you tried a Oscillating tool with a small blade? Still will give some vibration issues, if you want the Cadillac it is the Fein. Or if the same size, make a punch out of box steel. Dan
View bilyo's profile
bilyo
502 posts in 1367 days
#2 posted 01-29-2019 11:20 PM
I wonder if the tiny circular saw blades they make for the dremel rotary tool would work. Or maybe the diamond or carbide cut-off wheels like this or this. Or, maybe exacto saw blades.
MrUnix
7174 posts in 2464 days
#3 posted 01-29-2019 11:32 PM
Sounds like a perfect job for a scroll saw…
MrRon
#4 posted 01-29-2019 11:33 PM
I just thought about an oscillating multi tool before reading the replies. I think I will try one. Any recommendations on the least expensive and reliable brand? HF, Worx, Dremel, Fein, too expensive.
View Joe Andrews's profile
Joe Andrews
71 posts in 2264 days
#5 posted 01-29-2019 11:38 PM
Was going to suggest a small laser cutter, but they are around $350-$400 also.
View GR8HUNTER's profile
GR8HUNTER
5541 posts in 977 days
#6 posted 01-29-2019 11:39 PM
scroll saw for the win :<))
View Mainboom's profile
Mainboom
56 posts in 22 days
#7 posted 01-29-2019 11:55 PM
scroll saw
-- CRANE OPERATORS START EARLY because iron workers need their heros ready when they wake up
View ralbuck's profile
ralbuck
5660 posts in 2531 days
#8 posted 01-30-2019 12:48 AM
Use a SCROLLSAW—WITH A many TOOTH ( 25 + TPI) blade AND ALSO TAPE BOTH SIDES OF THE CUT!
EXPERIOMENT A LITTLE ON WASTE STOCK TO GET THE FEEL—RIGHT SPEED ETC. !
Let us know please what worked best for you. b If you do not have a scrollsaw and go to buy one——VARIABLE speed is a MUST!
-- Wood rescue is good for the environment and me! just rjR
View Hermit's profile
Hermit
228 posts in 1590 days
#9 posted 01-30-2019 01:41 AM
Scroll saw….2/0 blade….28 tooth per inch.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View Richard Lee's profile
Richard Lee
219 posts in 1040 days
#10 posted 01-30-2019 01:43 AM
Router and a template.
Or a sanding drum in the drill press , rough the hole then finish sand with a drum.
View EeerWoodworker's profile
EeerWoodworker
19 posts in 26 days
#11 posted 01-30-2019 02:12 AM
Get some really cheap 1/4” plywood and sandwich your 1/16” stuff between the 1/4 sheets and make the cut, any tearout will be in the 1/4” stuff.
You can use double sided scotch tape to hold the layers of plywood together.
View BFamous's profile
BFamous
253 posts in 385 days
#12 posted 01-30-2019 02:16 AM
Scroll saw is my vote as well… Though I think the #1 key overall is taping both sides as ralbuck points out.
If you don’t want to spend the money on a scroll saw, tape both sides and use a dremel and a cut off wheel.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View Redoak49's profile
Redoak49
3793 posts in 2253 days
#13 posted 01-30-2019 12:17 PM
Scroll saw with a #1 ultra reverse blade.
Note that it may take some practice to cut a straight line.
View Sylvain's profile
Sylvain
786 posts in 2764 days
#14 posted 01-30-2019 01:46 PM
You might borrow techniques used for marquetry.
Look at what Shipwright is doing in his various post and forum topics.
You might glue the plywood to another substrate with hide glue. Hide glue is reversible.
Or maybe sandwich the plywood between two (thin) cardboard sheets with hide glue. The paper/cardboard and hide glue would be easy to scrap with the help of some water (if you plywood has enough water resistance).
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View dhazelton's profile
dhazelton
2825 posts in 2561 days
#15 posted 01-30-2019 01:55 PM
An oscillating cuter from Harbor Freight will cost you under twenty buck to try. I’d go that route before investing in a scroll saw.
One of these old signmakers cutters always seemed interesting to me but I don’t know how much control you would have on the really small stuff. They show up n CL or ebay frequently.
showing 1 through 15 of 45 replies
